Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Subject: monitor subscription in areaDetector
To: "tech-talk@aps.anl.gov list" <tech-talk@aps.anl.gov>
Date: Fri, 27 Jan 2017 17:25:56 +0000
In areaDetector, for when we append NDAttribute data to NDArray objects, we have a class that can set up monitors on PVs. When a monitor event happens we record the data for use by the next NDArray object. However, we were setting a monitor callback handler for every connection event. This can result in multiple monitors being setup if the IOC that hosts the PV being monitored has been restarted a few times (resulting in a multiple connection events in the areaDetector IOC).
I was able to fix this in the same was as camonitor.c handles this, by using a flag to indicate that we’ve already connected (and set up a monitor) to a PV. Is this the most appropriate method to handle this? In the CA reference manual I see that there are functions like ca_clear_channel() and ca_clear_subscription() that we could possibly use on a disconnection event.
Cheers,
Matt
Data Acquisition and Control Engineer
Spallation Neutron Source
Oak Ridge National Lab
Re: monitor subscription in areaDetector Kasemir, Kay
Re: monitor subscription in areaDetector Andrew Johnson
Prev: RE: problem connecting serial device with moxa 5150A Mark Rivers
Next: Re: monitor subscription in areaDetector Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Prev: RE: Questions about set parameters to device by using epics Mark Rivers
ANJ, 14 Feb 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
