1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Re: TEWS TIP866 serial IP
To: <[email protected]>
Date: Thu, 26 Jan 2017 10:01:02 +0100
I quickly checked the code and found the following limitations:
1. The driver uses vxWorks functions instead of EPICS OSI functions.
2. The configure function can only be called from the vxWorks shell, not from iocsh. 3. The Makefile uses the PSI build system and is not compatible with the standard EPICS build system. You would have to write your own Makefile. 4. Parts of the code are under copyright by Tews (basically ioctl, isr and init). Publishing it may be illegal. I don't know if the source was under some license. The original files are on a Floppy which I cannot read any more. At least the original Tews driver documentation explicitly forbids unauthorized reproduction of the documentation. The files themselves claim:
Copyright (c) 1996
Tews Datentechnik GmbH
Maybe if you can convincingly assure that you have already a copy of the original Tews "TIP866 VxWorks Device Driver", I can give you my EPICS enabled version (basically a configure function which call some drvIpac and asyn functions).
Dirk
On 26.01.2017 09:15, Dirk Zimoch wrote:
On 25.01.2017 18:11, Gary Croke wrote:
Does anyone have a driver for the TEWS TIP866 (or TIP865) serial IP
module?
Gary
Hi Gary,
I have one. I will put it on github...
Dirk
TEWS TIP866 serial IP Gary Croke
Re: TEWS TIP866 serial IP Dirk Zimoch
Prev: Re: TEWS TIP866 serial IP Dirk Zimoch
Next: Re: TEWS TIP866 serial IP Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
