In most cases you do not have to set these environment variables.
When client and server are on the same network (same UDP broadcast domain), things should "just work" (tm). Only in non-standard setups, e.g. when IOCs or clients are in foreign (non-local) networks, these variables may be used to allow communication across LAN borders. The gateway (to external networks) is only needed when you have clients or servers in external networks. DNS is recommended, but not strictly necessary. Make sure the network configuration on both server and client is correct - e.g. wrong netmask entries can severely affect CA connectivity. Cheers, ~Ralph On Tue, Jan 24, 2017 at 4:51 PM, Arnab Dasgupta <[email protected]> wrote: Hi all,
ANJ, 21 Dec 2017 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
