1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: RE: problem connecting serial device with moxa 5150A
To: <[email protected]>, <[email protected]>, <[email protected]>
Date: Tue, 24 Jan 2017 14:41:34 +0000
Hi Mark,
When you say "arp looks good" did you also mean the  HWaddress   listed there for 192.168.127.254   matches that written on the moxa? I think you may be able to restrict access on the moxa itself by IP address, maybe that has been configured to only allow the windows box at the moment?
Freddie
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Mark Rivers
Sent: 24 January 2017 13:33
To: Sunny Badkul; [email protected]
I'm trying to help Sunny to connect from Linux to a serial port on a Moxa box.  It is not working, and I am stumped, so any ideas are welcome.
 From Windows he can telnet to it:
> when I telnet from windows
> telnet 192.168.127.254 4001
> It prompts a blank screen and for other IP or ports like 192.168.127.254 5064, 192.168.127.34 4732 etc. it simply says host not available so I think port 4001 should be good.
When he connects it to Linux he can ping it:
ping 192.168.127.254
PING 192.168.127.254 (192.168.127.254) 56(84) bytes of data.
64 bytes from 192.168.127.254<http://192.168.127.254>: icmp_seq=1 ttl=255 time=1.69 ms
64 bytes from 192.168.127.254<http://192.168.127.254>: icmp_seq=2 ttl=255 time=0.797 ms
64 bytes from 192.168.127.254<http://192.168.127.254>: icmp_seq=3 ttl=255 time=0.753 ms
ifconfig looks OK:
eth0      Link encap:Ethernet  HWaddr D8:CB:8A:9C:61:96
          inet addr:192.168.127.0  Bcast:192.168.127.255  Mask:255.255.255.0
          inet6 addr: fe80::dacb:8aff:fe9c:6196/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:16 errors:0 dropped:0 overruns:0 frame:0
          TX packets:63 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:1454 (1.4 Kb)  TX bytes:10799 (10.5 Kb)
arp looks good:
sbin/arp
Address                  HWtype  HWaddress           Flags Mask            Iface
10.128.0.254             ether   00:00:5e:00:01:83   C                     eth1
10.128.0.99              ether   00:04:96:6d:67:7f   C                     eth1
10.128.0.253             ether   00:04:96:15:5e:70   C                     eth1
10.128.0.238             ether   00:04:96:27:50:63   C                     eth1
10.128.0.244             ether   00:04:96:34:ea:f2   C                     eth1
10.128.0.252             ether   00:04:96:28:24:ce   C                     eth1
10.128.0.237             ether   00:04:96:51:a8:8b   C                     eth1
192.168.127.254          ether   00:90:e8:4e:6e:4e   C                     eth0
10.128.0.251             ether   00:04:96:16:c7:50   C                     eth1
10.128.0.249             ether   00:04:96:05:7a:13   C                     eth1
10.128.0.247             ether   00:04:96:36:54:da   C                     eth1
10.128.0.246             ether   00:04:96:21:d6:10   C                     eth1
The firewall is disabled:
 systemctl status SuSEfirewall2.service
SuSEfirewall2 phase 2
   Loaded: loaded (/usr/lib/systemd/system/SuSEfirewall2.service; disabled)
   Active: inactive (dead)
But when he tries to telnet from the Linux box it times out:
Trying 192.168.127.254...
telnet: connect to address 192.168.127.254<http://192.168.127.254>: Connection timed out
Any ideas what could be causing this?
problem connecting serial device with moxa 5150A Sunny Badkul
RE: problem connecting serial device with moxa 5150A Mark Rivers
Prev: RE: problem connecting serial device with moxa 5150A Mark Rivers
Next: Re: problem connecting serial device with moxa 5150A Matt Newville
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
