1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Re: problem connecting serial device with moxa 5150A
Date: Tue, 24 Jan 2017 15:07:31 +0100
Hm.
Does
ipables -L
say something interesting ?
Or can Wireshark help to find out what’s going on ?
> Am 24.01.2017 um 14:33 schrieb Mark Rivers <[email protected]>:
> I'm trying to help Sunny to connect from Linux to a serial port on a Moxa box.  It is not working, and I am stumped, so any ideas are welcome.
> From Windows he can telnet to it:
>> when I telnet from windows
>> telnet 192.168.127.254 4001
>> It prompts a blank screen and for other IP or ports like 192.168.127.254 5064, 192.168.127.34 4732 etc. it simply says host not available so I think port 4001 should be good.
> When he connects it to Linux he can ping it:
> ping 192.168.127.254
> PING 192.168.127.254 (192.168.127.254) 56(84) bytes of data.
> 64 bytes from 192.168.127.254<http://192.168.127.254>: icmp_seq=1 ttl=255 time=1.69 ms
> 64 bytes from 192.168.127.254<http://192.168.127.254>: icmp_seq=2 ttl=255 time=0.797 ms
> 64 bytes from 192.168.127.254<http://192.168.127.254>: icmp_seq=3 ttl=255 time=0.753 ms
> ifconfig looks OK:
> eth0      Link encap:Ethernet  HWaddr D8:CB:8A:9C:61:96
>          inet addr:192.168.127.0  Bcast:192.168.127.255  Mask:255.255.255.0
>          inet6 addr: fe80::dacb:8aff:fe9c:6196/64 Scope:Link
>          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
>          RX packets:16 errors:0 dropped:0 overruns:0 frame:0
>          TX packets:63 errors:0 dropped:0 overruns:0 carrier:0
>          collisions:0 txqueuelen:1000
>          RX bytes:1454 (1.4 Kb)  TX bytes:10799 (10.5 Kb)
> arp looks good:
> sbin/arp
> Address                  HWtype  HWaddress           Flags Mask            Iface
> 10.128.0.254             ether   00:00:5e:00:01:83   C                     eth1
> 10.128.0.99              ether   00:04:96:6d:67:7f   C                     eth1
> 10.128.0.253             ether   00:04:96:15:5e:70   C                     eth1
> 10.128.0.238             ether   00:04:96:27:50:63   C                     eth1
> 10.128.0.244             ether   00:04:96:34:ea:f2   C                     eth1
> 10.128.0.252             ether   00:04:96:28:24:ce   C                     eth1
> 10.128.0.237             ether   00:04:96:51:a8:8b   C                     eth1
> 192.168.127.254          ether   00:90:e8:4e:6e:4e   C                     eth0
> 10.128.0.251             ether   00:04:96:16:c7:50   C                     eth1
> 10.128.0.249             ether   00:04:96:05:7a:13   C                     eth1
> 10.128.0.247             ether   00:04:96:36:54:da   C                     eth1
> 10.128.0.246             ether   00:04:96:21:d6:10   C                     eth1
> The firewall is disabled:
> systemctl status SuSEfirewall2.service
> SuSEfirewall2 phase 2
>   Loaded: loaded (/usr/lib/systemd/system/SuSEfirewall2.service; disabled)
>   Active: inactive (dead)
> But when he tries to telnet from the Linux box it times out:
> Trying 192.168.127.254...
> telnet: connect to address 192.168.127.254<http://192.168.127.254>: Connection timed out
> Any ideas what could be causing this?
> Thanks,
> Mark
problem connecting serial device with moxa 5150A Sunny Badkul
RE: problem connecting serial device with moxa 5150A Mark Rivers
Prev: Re: Automatic start-up OPI in CSS Kasemir, Kay
Next: Re: problem connecting serial device with moxa 5150A Luca Cavalli
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Prev: RE: problem connecting serial device with moxa 5150A Mark Rivers
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
