Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Subject: Re: Support for Rigol DSA815 spectrum analyzer? [RF-128]
To: tech-talk <tech-talk@aps.anl.gov>, konrad@frib.msu.edu
Date: Mon, 23 Jan 2017 08:57:55 +0100 (CET)
Hi Martin,
for PSI (SwissFEL project) we have developed a simple stream device based device support for a similar spectrum analyzer (DSA875), I believe that device support should be compatible as the main difference is in the bandwidth.
You can find the device support here: https://github.com/paulscherrerinstitute/RigolDSA875
Note however that it is currently packaged for PSI build system (based on driver.makefile) so you might need to repackage it if you want to use it with EPICS build system.
The repository includes:
 - stream device protocol file: https://github.com/paulscherrerinstitute/RigolDSA875/blob/master/cfg/dsa875.p
 - startup script snippet: https://github.com/paulscherrerinstitute/RigolDSA875/blob/master/startup.cmd
 - database templates: https://github.com/paulscherrerinstitute/RigolDSA875/blob/master/SpectAnly.subs
 - caQtDm GUI: https://github.com/paulscherrerinstitute/RigolDSA875/tree/master/qt
 - small asub that generates X-axis (used for GUI plots): https://github.com/paulscherrerinstitute/RigolDSA875/blob/master/src/calcXAxis.c
The development of this device support was sponsored by PSI who is also the official maintainer, however we (Cosylab, as original developers) are available to answer any further questions.
Best regards,
Tom Slejko
 Tom SLEJKO, Group Leader / Senior Control system engineer
 Cosylab Switzerland GmbH
 http://www.cosylab.com
 Email: tom.slejko@cosylab.com
 Phone: +41 76 687 7673
 Skype: tomslejko
On Tue, Jan 17, 2017 at 12:53 AM, Konrad, Martin <konrad@frib.msu.edu> wrote:
> Hi,
> Does anyone know of any existing EPICS support for this low-end spectrum
> analyzer?
> Thanks a lot,
> Martin
> Martin Konrad
> Control System Engineer
> Facility for Rare Isotope Beams
> Michigan State University
> 640 South Shaw Lane
> East Lansing, MI 48824-1321, USA
> Tel. 517-908-7253
> Email: konrad@frib.msu.edu
Prev: RE: Why are the ui widgets all invisible? Mooney, Tim M.
Next: RE: Why are the ui widgets all invisible? Andrew Rhyder
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Prev: Support for Rigol DSA815 spectrum analyzer? [RF-128] Konrad, Martin
Next: Re: Support for Rigol DSA815 spectrum analyzer? [RF-128] Konrad, Martin
ANJ, 14 Feb 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
