Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Subject: Emulating the use of Global VxWorks Variables in OSI
To: Talk EPICS Tech <tech-talk@aps.anl.gov>
Date: Fri, 20 Jan 2017 10:00:46 -1000
Greetings,
I have a telescope system (our 8 meter primary mirror) which employs DTYP=vxWorks Variable in a ubiquitous manner.
In rtems this is not possible, so we're researching a refactor of the design. I've considered these two options below:
* a new device support module which exports key variables and updates them with sufficient scan rates. Our mirror loops are generally slow (as fast as 1 second).
* Use the SNCSEQ to keep C code and epics records synchronized.
Has anyone done something similar?
Thank you,
-Matt
Re: Emulating the use of Global VxWorks Variables in OSI Andrew Johnson
Prev: Re: Table properties in CSS BOY Kasemir, Kay
Next: Re: Emulating the use of Global VxWorks Variables in OSI Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
ANJ, 14 Feb 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
