Found this in RTEMS-Maillist:
Message: 1 Date: Mon, 13 Jun 2016 14:33:23 +0200 From: Sebastian Huber <[email protected]> To: Till Straumann <[email protected]>, RTEMS <[email protected]> Subject: Re: Standard RTEMS NFSv3 client now available via libbsd Message-ID: <[email protected]> Content-Type: text/plain; charset=utf-8; format=flowed On 10/06/16 16:47, Till Straumann wrote: > The client is V2, not V3. Thanks for clarification, this explains why its necessary to enable a legacy mode on one NFS server to be able to work with RTEMS clients. > > We have a low-priority project to add V3 but having a low priority I'm > not sure if or when it's going to happen... Another option would be to port the FreeBSD NFS client to RTEMS. For this we need a FreeBSD kernel file system layer to RTEMS file system layer adaptor. > > - Till > On 06/10/2016 05:20 AM, Sebastian Huber wrote: >> Hello, >> >> I imported a snapshot of the standard RTEMS NFSv3 client from Till >> Straumann to the libbsd (the new network stack). The RPC deamon uses >> a kqueue() instead of RTEMS events for synchronization. The zero-copy >> optimization by means of direct usage of mbufs is currently not >> available due to a lack of time and budget. >> -- Sebastian Huber, embedded brains GmbH
Heinz
On 19 January 2017 at 18:37:37, Andrew Johnson ([email protected]) wrote: Calling all RTEMS developers (Till, Eric, Michael, Heinz): Given the
statement below from Red Hat, are there any plans in the works to
support NFSv3 or later on RTEMS, or some other modern network filesystem
protocol?
On 01/19/2017 10:42 AM, Torsten Bögershausen wrote:
> But I am afraid that NFS 2 is no longer supported:
> <https://access.redhat.com/documentation/en-US/Red_Hat_Enterprise_Linux/7/html-single/Storage_Administration_Guide/index.html#ch-nfs>
The RTEMS NFSv2 client does talk to our RHEL-7.3 server with the
configuration change I posted for Mark, but the VxWorks 5.4.2 NFS client
broke somewhere between the RHEL-7.2 and 7.3 servers. VxWorks 5.5 has an
NFSv3 client (which is buggy, make sure you get all the available
patches) that works OK against a RHEL-7.3 server.
The APS now only has *2* production IOCs left running on EPICS 3.13.10,
having upgraded the others to Base-3.14.12 and VxWorks 5.5 or 6.9. This
solved the NFSv2 issue for VxWorks, but our RTEMS-4.9.2 and 4.10.2
systems are still stuck with NFSv2...
- Andrew
smime.p7s
Description: S/MIME cryptographic signature
- NFSv3 Client for RTEMS (was: Problem NFS mounting Centos 7 file systems from vxWorks 5.5) Andrew Johnson
- Problem NFS mounting Centos 7 file systems from vxWorks 5.5 Mark Rivers
- Re: Problem NFS mounting Centos 7 file systems from vxWorks 5.5 Torsten Bögershausen
- RE: Problem NFS mounting Centos 7 file systems from vxWorks 5.5 Mark Rivers
- Re: Problem NFS mounting Centos 7 file systems from vxWorks 5.5 Ralph Lange
- Re: Problem NFS mounting Centos 7 file systems from vxWorks 5.5 Andrew Johnson
Table properties in CSS BOY Shantonu Sahoo
<2017>
<2017>
ANJ, 21 Dec 2017 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
