Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Subject: Re: Problem NFS mounting Centos 7 file systems from vxWorks 5.5
To: tech-talk@aps.anl.gov
Date: Thu, 19 Jan 2017 14:16:12 +0100
Hi Mark,
I had a similar problem mounting a NFS share from a debian server onto a
LynxOS system with NFS4 and NFS3 enabled on the server but the client only
capable of NFS2.
I had to switch off NFS4 and enable NFS2 on the server to get the mount
working. Enabling only NFS2 and leaving NFS4 running, it would not work. It
seems that NFS4 will not fallback to other versions if the client does not
connect with NFS4.
Hope that helps a bit,
Jörn
Problem NFS mounting Centos 7 file systems from vxWorks 5.5 Mark Rivers
Re: Problem NFS mounting Centos 7 file systems from vxWorks 5.5 Torsten Bögershausen
RE: Problem NFS mounting Centos 7 file systems from vxWorks 5.5 Mark Rivers
Prev: Re: Problem NFS mounting Centos 7 file systems from vxWorks 5.5 Ralph Lange
Next: RE: Problem NFS mounting Centos 7 file systems from vxWorks 5.5 Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Prev: NFSv3 Client for RTEMS (was: Problem NFS mounting Centos 7 file systems from vxWorks 5.5) Andrew Johnson
Next: Re: Problem NFS mounting Centos 7 file systems from vxWorks 5.5 Jeong Han Lee
ANJ, 14 Feb 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
