1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: RE: Problem compiling StreamDevice on Visual Studio 2015
To: <[email protected]>, <[email protected]>
Cc: [email protected]
Date: Thu, 19 Jan 2017 01:31:08 +0000
Hi Mark,
If you add some extra space around P I think it will work i.e.   result.print("%" P "d,%" P "d,%" P "d:\033[37m", offs, len, cap);
The additional spaces should not change the final string concatenation result
Freddie
From: [email protected] [mailto:[email protected]] On Behalf Of Mark Rivers
Sent: 19 January 2017 01:17
To: Mark Rivers; 'Dirk Zimoch'
I just found that P is defined as:
#define P PRINTF_SIZE_T_PREFIX
The format string was changed in this commit:
commit 73cba130c32df2031a3d862ed9daf5ba00d5173b
Author: zimoch <zimoch>
Date:   Thu May 16 08:28:34 2013 +0000
    use ssize_t for signed index types. Win has no ssize_t, use ptrdiff_t instead.
    use P instead of S as shortcut for PRINTF_SIZE_T_PREFIX because some OK already use S.
which did this:
-#define S PRINTF_SIZE_T_PREFIX
+#define P PRINTF_SIZE_T_PREFIX
-    result.print("%"S"d,%"S"d,%"S"d:\033[37m", offs, len, cap);
+    result.print("%"P"d,%"P"d,%"P"d:\033[37m", offs, len, cap);
But that does not tell me how to fix it.
Sent: Wednesday, January 18, 2017 7:09 PM
To: 'Dirk Zimoch'
Subject: Problem compiling StreamDevice on Visual Studio 2015
Hi Dirk and all,
The following line compiles OK on Visual Studio 2010, but fails on Visual Studio 2015:
This is the error:
cl -EHsc -GR                -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE   -Ox -GL -Oy-   -W3 -w44355 -w44344        -MT  -TP  -I. -I../O.Common -I.
-I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include      -IJ:/epics/support/asyn-4-31/include   -IJ:/epics/support/calc-3-6-1/include
-IJ:/epics/support/sscan-2-10-2/include -IH:/epics/base-3.15.5/include/compiler/msvc -IH:/epics/base-3.15.5/include/os/WIN32 -IH:/epics/base-3.15.5/include        -c ../StreamBuffer.cc
StreamBuffer.cc
../StreamBuffer.cc(317): error C3688: invalid literal suffix 'P'; literal operator or literal operator template 'operator ""P' not found
H:/epics/base-3.15.5/configure/RULES_BUILD:233: recipe for target 'StreamBuffer.obj' failed
make[1]: *** [StreamBuffer.obj] Error 2
make[1]: Leaving directory 'J:/epics/support/stream/StreamDevice/src/O.windows-x64-static-vs2015'
H:/epics/base-3.15.5/configure/RULES_ARCHS:58: recipe for target 'install.windows-x64-static-vs2015' failed
make: *** [install.windows-x64-static-vs2015] Error 2
Can someone explain what the P characters in that format string do, and how to get this to compile on Visual Studio 2015?
RE: Problem compiling StreamDevice on Visual Studio 2015 Mark Rivers
Prev: RE: Problem compiling StreamDevice on Visual Studio 2015 Mark Rivers
Next: RE: Problem compiling StreamDevice on Visual Studio 2015 Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
