1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Re: Question about EDM installing on Fedora20-64bit operation system----cannot find -lXtst problem
To: <[email protected]>
Date: Wed, 18 Jan 2017 13:44:36 -0200
Hello Zhefu,
apparently is missing libXtst, you should install it probably like this:
sudo yum install libXtst.x86_64 libXtst-devel.x86_64
Em 18-01-2017 13:38, lzf neu escreveu:
I try to compile EDM on Fedora20-64bit operation system and the errors
occured below:
[root@localhost edm]# make
/usr/bin/ld: cannot find -lXtst
collect2: error: ld returned 1 exit status
make[2]: *** [libcfcaa62e-8199-11d3-a77f-00104b8742df.so] Error 1
make[2]: Leaving directory
`/home/user/epics/extensions/src/edm/lib/O.linux-x86_64'
make[1]: *** [install.linux-x86_64] Error 2
make[1]: Leaving directory `/home/user/epics/extensions/src/edm/lib'
make: *** [lib.install] Error 2
Could anyone give me some suggestions and thanks in advance.
Zhefu
Gabriel Fedel
Software de Operação das Linhas de Luz
Laboratório Nacional de Luz Síncrotron – (LNLS)
Centro Nacional de Pesquisa em Energia e Materiais (CNPEM)
[email protected] | +55 (19) 3512 1226
www.lnls.cnpem.br
Question about EDM installing on Fedora20-64bit operation system----cannot find -lXtst problem lzf neu
Prev: Question about EDM installing on Fedora20-64bit operation system----cannot find -lXtst problem lzf neu
Next: Re: CA server bind failure on Windows Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Next: Problem NFS mounting Centos 7 file systems from vxWorks 5.5 Mark Rivers
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
