Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Subject: Re: Knowing if a server application is running
To: Ralph Lange <ralph.lange@gmx.de>, EPICS Tech Talk <tech-talk@aps.anl.gov>
Date: Wed, 18 Jan 2017 14:01:21 +0100
Thanks for all the input, many nice solutions
as always many ways to achieve the wished result.
I ended op with the solution below which matches my level of EPICS'ing nicely.
Best
Bo
On 2017-01-17 19:49, Ralph Lange wrote:
There are several ways to do that.
One that I have been using (and that is similar to Mark Rivers' suggestion) is a dead-man-switch setup:
A calc/calcout record is set up as always counting down, with SCAN e.g. set to 1 second and a CALC of e.g. "VAL>0?VAL-1:0".
The LOW and LOLO fields can be used to set a yellow and red alarm.
The monitored-system (e.g. your Matlab service) resets the timer regularly by e.g writing a 10 into the calc record every couple of seconds.
Using a calcout record the OUT link can be used (with OOPT set as "Transition to Zero") to trigger something when the service is dead.
This only needs a single record (EPICS database golf hole-in-one!), doesn't have to handle counter overflow situations, allows for a yellow and red alarm, lets the client freely decide for how long it will snooze, and is quite robust with respect to slightly irregular write intervals of the monitored-system (e.g. if the service is under high load).
Cheers,
~Ralph
Knowing if a server application is running Bo Jakobsen
Re: Knowing if a server application is running Ralph Lange
Prev: RE: problem connecting serial device with moxa 5150A Mark Rivers
Next: RE: problem connecting serial device with moxa 5150A Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Prev: Re: Knowing if a server application is running Ralph Lange
Next: Help regarding siemens S7 200 smart communcation Arnab Dasgupta
ANJ, 14 Feb 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
