Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Subject: Knowing if a server application is running
To: "tech-talk@aps.anl.gov" <tech-talk@aps.anl.gov>
Date: Tue, 17 Jan 2017 16:35:16 +0100
Hi all,
I am building an system based on EPICS and Matlab.
The idea of the system is that a "server" is running in Matlab. This server which monitors and manipulates EPICS records according to some logics. This works very nicely and stable (even as I known that I should properly write it all as seq code, but that is out of the scope of my current project).
My problem is now that I would like to indicate to the user if the Matlab server is running or not through an EPICS record.
My thought was to periodically (e.g. at least ones per second) update a soft record from the Matlab server. But how can I from EPICS test if this has happened. It could e.g. be a time stamp, or a "running number".
Any input will be mostly appreciated
Bo
Re: Knowing if a server application is running Andrew Johnson
Re: Knowing if a server application is running Matt Newville
RE: Knowing if a server application is running Mark Rivers
Re: Knowing if a server application is running Ralph Lange
Prev: Re: Looking for someone to help building the control system of XAFS/XRF beamline at SESAME Mark Clift
Next: Re: Knowing if a server application is running Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
ANJ, 14 Feb 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
