Am 14.01.2017 um 16:52 schrieb Ben Franksen:
> Anyway, I can suppress the error message with make-3.81/gcc-4.7.2 by
> adding explicit dependencies of the relevant .d files:
> lexer.o: snl.h
> type_check.o: snl.h
> var_types.o: snl.h
> The other combination (make-4.1/gcc-5.4.0) is not able to complete
> successfully when run directly after rm -f snl.h *.d, even with these
> extra dependencies listed.
Please ignore the last sentence, I made a mistake. Adding the explicit
dependencies really does work on my machine, too. But I still think this
is not the right way to fix the problem. Manually added dependencies are
brittle in the face of evolving code, which is why we auto-generate them
in the first place.
A better fix (I think) is to set
HDEPENDS_METHOD=MKMF
in src/snc/Makefile (in the CONFIG section). This lets the EPICS build
system use mkmf.pl to generate the dependencies even on platforms where
the C compiler supports the appropriate flags to generate dependencies.
(Note that for 3.14 I had already copied the corresponding rule from
base-3.15 which is why the problem manifests only with 3.15).
(I noticed that after I do 'rm snl.h *.d' this still does not
re-generate the .d files for the three files that include snl.h. It is
hard for me to judge whether this may cause problems in the future.)
Anyway, if this works for you (Mark), then I will make a new release
with this fix (and with a fix for the other build problem you reported).
Cheers
Ben
signature.asc
Description: OpenPGP digital signature
- RE: Problem with parallel make with seq 2.2.4 on Linux Mark Rivers
- Problem with parallel make with seq 2.2.4 on Linux Mark Rivers
- Re: Problem with parallel make with seq 2.2.4 on Linux Andrew Johnson
- Re: Problem with parallel make with seq 2.2.4 on Linux Ben Franksen
<2017>
<2017>
