I only find one functional change to dbCa between .5 and .6 but I can't
see how it would cause this problem.
https://github.com/epics-base/epics-base/commit/c56091978c8d91c95742d49d1315acc478748e3f
If you are game for a little debugging, I'd be interested to know if
connectionCallback() and eventCallback() in dbCa.c are ever executed.
On 01/12/2017 07:38 AM, Mark Rivers wrote:
> Folks,
> We are having problems with all of our vxWorks IOCs. We recently upgraded from base 3.14.12.5 to 3.14.12.6. We have not changed the version of vxWorks, which is 6.9.4.1. We did update the Linux server on which we build and boot the IOCs from Fedora 15 to Centos 7.
> The IOCs work fine as CA servers, all Linux and Windows clients can connect to them fine. But the IOCs are not working as CA clients. All records with CA links to other IOCs fail to connect, they have STAT=LINK. SNL programs can connect to local PVs but not to PVs on other IOCs. This is true whether the IOC hosting the target PV is running on Linux or VxWorks.
> Here is an example where the DOL field points to a valid PV in another VxWorks IOC. When I test the record it has STAT=LINK.
> ioc13idc> dbtr "13IDC:filter:EnergyBeamline",10
> ACKS: INVALID ACKT: YES ADEL: 0
> ALST: 74.9806201550387 AOFF: 0 ASG:
> ASLO: 0 BKPT: 00 DESC: 13-ID-C Filters beamline energy
> DISA: 0 DISP: 0 DISS: NO_ALARM DISV: 1
> DOL:CA_LINK 13BMC:m1.RBV NPP NMS DRVH: 0 DRVL: 0
> DTYP: Soft Channel EGU: EGUF: 0 EGUL: 0
> EOFF: 0 ESLO: 1 EVNT: 0
> FLNK:DB_LINK 13IDC:filter:Energy HHSV: NO_ALARM HIGH: 0
> HIHI: 0 HOPR: 0 HSV: NO_ALARM HYST: 0
> INIT: 0 IVOA: Continue normally IVOV: 0
> LALM: 74.9806201550387 LBRK: 0 LCNT: 0
> LINR: NO CONVERSION LLSV: NO_ALARM LOLO: 0 LOPR: 0
> LOW: 0 LSV: NO_ALARM MDEL: 0
> MLST: 74.9806201550387 NAME: 13IDC:filter:EnergyBeamline
> NSEV: NO_ALARM NSTA: NO_ALARM OIF: Full OMOD: 0
> OMSL: closed_loop ORAW: 75 ORBV: 0 OROC: 0
> OUT:CONSTANT OVAL: 74.9806201550387 PACT: 0
> PHAS: 0 PINI: NO PREC: 4 PRIO: LOW
> PROC: 1 PUTF: 0 PVAL: 74.9806201550387
> RBV: 0 ROFF: 0 RPRO: 0 RVAL: 75
> SCAN: Passive SDIS:CONSTANT SEVR: INVALID SIML:CONSTANT
> SIMM: NO SIMS: NO_ALARM SIOL:CONSTANT STAT: LINK
> TIME: 2017-01-11 18:11:02.007588962 TPRO: 0 TSE: 0
> TSEL:CONSTANT UDF: 0 VAL: 74.9806201550387
> value = 0 = 0x0
> However, that 13BMC:m1.RBV PV works fine from Linux caget:
> corvette:~/support/CARS/iocBoot>caget 13BMC:m1.RBV
> 13BMC:m1.RBV -0.856875
> The record above works fine with CP links as long as the PVs are local to that IOC.
> This is on a different IOC where the SNL program connects fine to local PVs, but fails to connect to the 2 PVs that are in another IOC.
> epics> seqShow BM13_Energy -
> State Program: "BM13_Energy"
> thread priority = 50
> number of state sets = 1
> number of syncQ queues = 0
> number of channels = 26
> number of channels assigned = 26
> number of channels connected = 24
> number of channels monitored = 24
> options: async=0, debug=0, newef=1, reent=0, conn=1
> State Set: "Energy"
> thread name = BM13_Energy; Thread id = 0x211e110
> First state = "init"
> Current state = "init"
> Previous state = "init"
> Elapsed time since state was entered = -Inf seconds
> Wake up delay = Inf seconds
> Get in progress = [00000000000000000000000000]
> Put in progress = [00000000000000000000000000]
> epics> seqChanShow BM13_Energy -
> Number of channels=26
> View: State set Energy
> #14 of 26:
> Variable name: "xt_ht"
> type = double
> count = 1
> Value = 0
> Assigned to "13BMD:m22.VAL"
> Not connected
> Monitored
> Not sync'ed
> Status = -2
> Severity = -1
> Message = disconnected
> Time stamp = <undefined>
> Next? (+/- skip count)
> This is the output of epicsPrtEnvParams:
> ioc13idc> epicsPrtEnvParams
> EPICS_AR_PORT: 7002
> EPICS_CAS_AUTO_BEACON_ADDR_LIST is undefined
> EPICS_CAS_BEACON_ADDR_LIST is undefined
> EPICS_CAS_BEACON_PERIOD is undefined
> EPICS_CAS_BEACON_PORT is undefined
> EPICS_CAS_IGNORE_ADDR_LIST is undefined
> EPICS_CAS_INTF_ADDR_LIST is undefined
> EPICS_CAS_SERVER_PORT is undefined
> EPICS_CA_ADDR_LIST is undefined
> EPICS_CA_AUTO_ADDR_LIST: YES
> EPICS_CA_BEACON_PERIOD: 15.0
> EPICS_CA_CONN_TMO: 30.0
> EPICS_CA_MAX_ARRAY_BYTES: 88000
> EPICS_CA_MAX_SEARCH_PERIOD: 300.0
> EPICS_CA_NAME_SERVERS is undefined
> EPICS_CA_REPEATER_PORT: 5065
> EPICS_CA_SERVER_PORT: 5064
> EPICS_CMD_PROTO_PORT is undefined
> EPICS_IOC_LOG_FILE_COMMAND is undefined
> EPICS_IOC_LOG_FILE_LIMIT: 1000000
> EPICS_IOC_LOG_FILE_NAME is undefined
> EPICS_IOC_LOG_INET: 164.54.160.182
> EPICS_IOC_LOG_PORT: 7004
> EPICS_TIMEZONE: CUS::360:031302:110602
> EPICS_TS_NTP_INET is undefined
> IOCSH_HISTSIZE: 50
> IOCSH_PS1: epics>
> value = 0 = 0x0
> This is the output of the "version" and "coreRelease" commands on vxWorks.
> ioc13bma> version
> VxWorks (for Motorola MVME2700 - MPC 750) version 6.9.4.1.
> Kernel: WIND version 2.13.
> Made on Jul 27 2015 17:59:12.
> Boot line:
> dc(0,0)corvette:/usr/local/vw/VX6941/mv2700-dev6-debug e=164.54.160.74:ffffff00 h=164.54.160.82 u=iocboot tn=ioc13bma s=/home/epics/support/CARS/iocBoot/ioc13bma/st.cmd
> value = 180 = 0xb4
> ioc13bma> coreRelease
> ## EPICS R3.14.12.6
> ## EPICS Base built Jan 9 2017
> value = 0 = 0x0
> ioc13bma>
> Any ideas on what the problem could be and any diagnostics to run to track it down?
> Thanks,
> Mark
- Problems with vxWorks IOCs on base 3.14.12.6 Mark Rivers
Support for Queensgate NPC-D-5110DS piezo controller edmund.warrick
RE: Problems with vxWorks IOCs on base 3.14.12.6 Mark Rivers
<2017>
Re: Problems with vxWorks IOCs on base 3.14.12.6 Martin L. Smith
<2017>
