I had a look at the code in drvVxi11.c and by moving the SRQ code inside the ‘isGpibLink’ test everything seems to work. This change also gets VXI-11 communication working with some other instruments that also failed before.
diff -U50 -r ../asyn4-30.orig/asyn/vxi11/drvVxi11.c ./asyn/vxi11/drvVxi11.c
--- ../asyn4-30.orig/asyn/vxi11/drvVxi11.c 2016-08-23 09:23:36.000000000 -0700
+++ ./asyn/vxi11/drvVxi11.c 2017-01-10 09:19:06.969887000 -0800
@@ -909,102 +909,102 @@
pvxiPort->server.lid = link;
pvxiPort->server.connected = TRUE;
pvxiPort->ctrlAddr = -1;
if(pvxiPort->isGpibLink) {
/* Ask the controller's gpib address.*/
status = vxiBusStatus(pvxiPort,
VXI_BSTAT_BUS_ADDRESS,pvxiPort->defTimeout,&pvxiPort->ctrlAddr);
if(status!=asynSuccess) {
asynPrint(pasynUser,ASYN_TRACE_ERROR,
"%s vxiConnectPort cannot read bus status initialization aborted\n",
pvxiPort->portName);
if (pvxiPort->server.connected)
vxiDisconnectPort(pvxiPort);
return status;
/* initialize the vxiPort structure with the data we have got so far */
pvxiPort->primary[pvxiPort->ctrlAddr].primary.lid = link;
pvxiPort->primary[pvxiPort->ctrlAddr].primary.connected = TRUE;
/* now we can use vxiBusStatus; if we are not the controller fail */
status = vxiBusStatus(pvxiPort, VXI_BSTAT_SYSTEM_CONTROLLER,
pvxiPort->defTimeout,&isController);
"%s vxiConnectPort vxiBusStatus error initialization aborted\n",
return status;
if(isController == 0) {
status = vxiBusStatus(pvxiPort, VXI_BSTAT_CONTROLLER_IN_CHARGE,
return asynError;
"%s vxiConnectPort neither system controller nor "
"controller in charge -- initialization aborted\n",
return asynError;
+ vxiCreateIrqChannel(pvxiPort,pasynUser);
- vxiCreateIrqChannel(pvxiPort,pasynUser);
pasynManager->exceptionConnect(pvxiPort->pasynUser);
return asynSuccess;
static asynStatus vxiDisconnectPort(vxiPort *pvxiPort)
int addr,secondary;
asynUser *pasynUser = pvxiPort->pasynUser;
if(!pvxiPort->server.connected) {
"%s vxiDisconnectPort but not connected\n",pvxiPort->portName);
return asynError;
if(pasynUser) asynPrint(pasynUser,ASYN_TRACE_FLOW,
"%s vxiDisconnectPort\n",pvxiPort->portName);
if(!pvxiPort->isSingleLink)
for(addr = 0; addr < NUM_GPIB_ADDRESSES; addr++) {
devLink *pdevLink;
pdevLink = &pvxiPort->primary[addr].primary;
if(pdevLink->connected) {
if(addr!=pvxiPort->ctrlAddr) {
vxiDestroyDevLink(pvxiPort, pdevLink->lid);
vxiDisconnectException(pvxiPort,addr);
pdevLink->lid = 0;
pdevLink->connected = FALSE;
for(secondary = 0; secondary < NUM_GPIB_ADDRESSES; secondary++) {
pdevLink = &pvxiPort->primary[addr].secondary[secondary];
vxiDisconnectException(pvxiPort,(addr*100 + secondary));
pdevLink->lid = 0;
vxiDestroyIrqChannel(pvxiPort);
vxiDestroyDevLink(pvxiPort, pvxiPort->server.lid);
pvxiPort->server.connected = FALSE;
pvxiPort->server.lid = 0;
clnt_destroy(pvxiPort->rpcClient);
pasynManager->exceptionDisconnect(pvxiPort->pasynUser);
return asynSuccess;
static void vxiReport(void *drvPvt,FILE *fd,int details)
