Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Subject: DSO missing from command line Error in Ubuntu 16.04 LTS
To: "EPICS Tech-Talk" <tech-talk@aps.anl.gov>
Cc: Anindya Roy <r_ani@vecc.gov.in>
Date: Tue, 10 Jan 2017 17:44:38 +0530
I am getting an abnormal error while building an application in EPICS in ubuntu 16.04 x86 platform. I could successfully build EPICS base 3.15.5 and asysn 4-30 without error. But get the following error:
make[3]: Entering directory '/home/epics/base-3.15.5/asyn4-30/tcpscc/tcpsccApp/src/O.linux-x86'
/usr/bin/g++ -o tcpscc  -L/home/epics/base-3.15.5/asyn4-30/tcpscc/lib/linux-x86 -Wl,-rpath,/home/epics/base-3.15.5/asyn4-30/tcpscc/lib/linux-x86           -rdynamic -m32            tcpscc_registerRecordDeviceDriver.o tcpsccMain.o    -ldevtcpscc -lasyn
/usr/bin/ld: tcpscc_registerRecordDeviceDriver.o: undefined reference to symbol 'iocshRegisterCommon'
/home/epics/base-3.15.5/asyn4-30/tcpscc/lib/linux-x86/libdbCore.so.3.15.5: error adding symbols: DSO missing from command line
collect2: error: ld returned 1 exit status
/home/epics/base-3.15.5/configure/RULES_BUILD:201: recipe for target 'tcpscc' failed
make[3]: *** [tcpscc] Error 1
make[3]: Leaving directory '/home/epics/base-3.15.5/asyn4-30/tcpscc/tcpsccApp/src/O.linux-x86'
/home/epics/base-3.15.5/configure/RULES_ARCHS:58: recipe for target 'install.linux-x86' failed
make[2]: *** [install.linux-x86] Error 2
make[2]: Leaving directory '/home/epics/base-3.15.5/asyn4-30/tcpscc/tcpsccApp/src'
/home/epics/base-3.15.5/configure/RULES_DIRS:84: recipe for target 'src.install' failed
make[1]: *** [src.install] Error 2
make[1]: Leaving directory '/home/epics/base-3.15.5/asyn4-30/tcpscc/tcpsccApp'
/home/epics/base-3.15.5/configure/RULES_DIRS:84: recipe for target 'tcpsccApp.install' failed
make: *** [tcpsccApp.install] Error 2
I have tried with different version of epics and asyn, but the error persists. Is it related to OS?
शांतनु साहू / Shantonu Sahoo
Re: DSO missing from command line Error in Ubuntu 16.04 LTS Johnson, Andrew N.
Prev: Looking for someone to help building the control system of XAFS/XRF beamline at SESAME Messaoud Harfouche
Next: Re: Looking for someone to help building the control system of XAFS/XRF beamline at SESAME Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Prev: Looking for someone to help building the control system of XAFS/XRF beamline at SESAME Mark Clift
Next: Re: DSO missing from command line Error in Ubuntu 16.04 LTS Johnson, Andrew N.
ANJ, 14 Feb 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
