1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: RE: synApps_5_8 build error
To: "Abdalla Ahmad" <[email protected]>, "[email protected]" <[email protected]>
Date: Sun, 8 Jan 2017 13:49:35 +0000
If you change /home/control/epics/support/synApps_5_8/support/configure/RELEASE to define
SUPPORT=/home/control/epics/support/synApps_5_8/support/
EPICS_BASE=/home/control/epics/base-3.14.12.3
does that fix the problem?  Maybe it is not picking up the environment variables correctly.
From: [email protected] [[email protected]] on behalf of Abdalla Ahmad [[email protected]]
Sent: Sunday, January 08, 2017 12:26 AM
To: [email protected]
Subject: synApps_5_8 build error
Hi
I downloaded the mentioned version of synApps and I modified SUPPORT and EPICS_BASE in configure/RELEASE file as:
SUPPORT=$(SYNAPPS_SUPPORT)
EPICS_BASE=$(ENV_EPICS_BASE)
These variables are already defined in .bashrc and exported. The list of modules for our site is
Asyn
Allen_Bradlley
Autosave
Busy (Added to resolve a similar error at compiling asyn )
Calc
IP
IPAC
Motor
SNCSEQ
SSCAN
STREAM
Executing 'make release' then make gives the following:
Definition of SNCSEQ conflicts with SUPPORT support.
In this application a RELEASE file defines
                SNCSEQ = /home/control/epics/support/synApps_5_8/support/seq-2-2-1
but SUPPORT at /home/control/epics/support/synApps_5_8/support defines
                SNCSEQ = /seq-2-2-1
Definition of EPICS_BASE conflicts with SUPPORT support.
                EPICS_BASE = /home/control/epics/base-3.14.12.3
                EPICS_BASE =
Definition of SUPPORT conflicts with SUPPORT support.
                SUPPORT = /home/control/epics/support/synApps_5_8/support
                SUPPORT =
I have no clue of where these wrong definitions are. I thought of giving hard coded paths for the aforementioned variables instead of env ones and the build works fine. I believe on synApps 5.6 we did not face that error.
Best Regards,
Abdalla Ahmad
Control Engineer
SESAME
Allan, Jordan.
Tel: (+962-5) 3511348 , ext. 265
Fax: (+962-5) 3511423
Mob: (+962-7)88183296
www.sesame.org.jo<http://www.sesame.org.jo/>
RE: synApps_5_8 build error Abdalla Ahmad
Prev: synApps_5_8 build error Abdalla Ahmad
Next: RE: synApps_5_8 build error Abdalla Ahmad
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
