Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Subject: RE: Installing areadetector on raspberry-pi2 OS raspbian pixels
To: "avanish@rrcat.gov.in" <avanish@rrcat.gov.in>, "tech-talk@aps.anl.gov" <tech-talk@aps.anl.gov>
Date: Thu, 5 Jan 2017 12:27:01 +0000
The problem is that you are also using a very old version of asyn.  You should update to a more recent version of asyn.  areaDetector requires the following modules from synApps
asyn
calc
sscan
autosave
busy
iocStats
I recommend that you get the latest released version of each of these.  They are all on Github:
https://github.com/epics-modules
From: tech-talk-bounces@aps.anl.gov [tech-talk-bounces@aps.anl.gov] on behalf of avanish@rrcat.gov.in [avanish@rrcat.gov.in]
Sent: Thursday, January 05, 2017 3:25 AM
To: tech-talk@aps.anl.gov
I tried to follow INSTALL_GUIDE.md from github repository.
Now I am getting following error when trying to make.
pi@raspberrypi:~/Apps/epics/synApps_5_6/support/areaDetector-master $ make
make -C
/home/pi/Apps/epics/synApps_5_6/support/areaDetector-master/ADSupport
install
make[1]: Entering directory
'/home/pi/Apps/epics/synApps_5_6/support/areaDetector-master/ADSupport'
make -C ./configure install
make[2]: Entering directory
'/home/pi/Apps/epics/synApps_5_6/support/areaDetector-master/ADSupport/configure'
make -C O.linux-arm -f ../Makefile TOP=../.. \
    T_A=linux-arm install
make[3]: Entering directory
'/home/pi/Apps/epics/synApps_5_6/support/areaDetector-master/ADSupport/configure/O.linux-arm'
perl //home/pi/Apps/epics/base-3.14.12.6/bin/linux-arm/convertRelease.pl
checkRelease
make[3]: Leaving directory
make[2]: Leaving directory
make -C ./supportApp install
'/home/pi/Apps/epics/synApps_5_6/support/areaDetector-master/ADSupport/supportApp'
make -C ./netCDFSrc install
'/home/pi/Apps/epics/synApps_5_6/support/areaDetector-master/ADSupport/supportApp/netCDFSrc'
make -C O.linux-arm -f ../Makefile TOP=../../.. \
make[4]: Entering directory
'/home/pi/Apps/epics/synApps_5_6/support/areaDetector-master/ADSupport/supportApp/netCDFSrc/O.linux-arm'
make[4]: Nothing to be done for 'install'.
make[4]: Leaving directory
make -C ./jpegSrc install
'/home/pi/Apps/epics/synApps_5_6/support/areaDetector-master/ADSupport/supportApp/jpegSrc'
'/home/pi/Apps/epics/synApps_5_6/support/areaDetector-master/ADSupport/supportApp/jpegSrc/O.linux-arm'
make -C ./zlibSrc install
'/home/pi/Apps/epics/synApps_5_6/support/areaDetector-master/ADSupport/supportApp/zlibSrc'
'/home/pi/Apps/epics/synApps_5_6/support/areaDetector-master/ADSupport/supportApp/zlibSrc/O.linux-arm'
make -C ./tiffSrc install
'/home/pi/Apps/epics/synApps_5_6/support/areaDetector-master/ADSupport/supportApp/tiffSrc'
'/home/pi/Apps/epics/synApps_5_6/support/areaDetector-master/ADSupport/supportApp/tiffSrc/O.linux-arm'
make -C ./xml2Src install
'/home/pi/Apps/epics/synApps_5_6/support/areaDetector-master/ADSupport/supportApp/xml2Src'
'/home/pi/Apps/epics/synApps_5_6/support/areaDetector-master/ADSupport/supportApp/xml2Src/O.linux-arm'
make -C ./szipSrc install
'/home/pi/Apps/epics/synApps_5_6/support/areaDetector-master/ADSupport/supportApp/szipSrc'
'/home/pi/Apps/epics/synApps_5_6/support/areaDetector-master/ADSupport/supportApp/szipSrc/O.linux-arm'
make -C ./hdf5Src install
'/home/pi/Apps/epics/synApps_5_6/support/areaDetector-master/ADSupport/supportApp/hdf5Src'
'/home/pi/Apps/epics/synApps_5_6/support/areaDetector-master/ADSupport/supportApp/hdf5Src/O.linux-arm'
make -C ./nexusSrc install
'/home/pi/Apps/epics/synApps_5_6/support/areaDetector-master/ADSupport/supportApp/nexusSrc'
'/home/pi/Apps/epics/synApps_5_6/support/areaDetector-master/ADSupport/supportApp/nexusSrc/O.linux-arm'
make[1]: Leaving directory
make -C /home/pi/Apps/epics/synApps_5_6/support/areaDetector-master/ADCore
install
'/home/pi/Apps/epics/synApps_5_6/support/areaDetector-master/ADCore'
'/home/pi/Apps/epics/synApps_5_6/support/areaDetector-master/ADCore/configure'
'/home/pi/Apps/epics/synApps_5_6/support/areaDetector-master/ADCore/configure/O.linux-arm'
checkRelease
make -C ./ADApp install
'/home/pi/Apps/epics/synApps_5_6/support/areaDetector-master/ADCore/ADApp'
make -C ./Db install
'/home/pi/Apps/epics/synApps_5_6/support/areaDetector-master/ADCore/ADApp/Db'
'/home/pi/Apps/epics/synApps_5_6/support/areaDetector-master/ADCore/ADApp/Db/O.linux-arm'
make -C ./ADSrc install
'/home/pi/Apps/epics/synApps_5_6/support/areaDetector-master/ADCore/ADApp/ADSrc'
'/home/pi/Apps/epics/synApps_5_6/support/areaDetector-master/ADCore/ADApp/ADSrc/O.linux-arm'
/usr/bin/g++ -c  -D_GNU_SOURCE -D_DEFAULT_SOURCE             -DUNIX
-Dlinux     -O3 -g   -Wall           -fPIC -MMD -I. -I../O.Common -I. -I..
-I../../../include/os/Linux -I../../../include
-I//home/pi/Apps/epics/base-3.14.12.6/include/os/Linux
-I/home/pi/Apps/epics/synApps_5_6/support/asyn-4-18/include
-I/home/pi/Apps/epics/synApps_5_6/support/areaDetector-master/ADSupport/include/os/Linux
-I/home/pi/Apps/epics/synApps_5_6/support/areaDetector-master/ADCore/include
                 ../asynNDArrayDriver.cpp
../asynNDArrayDriver.cpp: In member function ‘virtual asynStatus
asynNDArrayDriver::readGenericPointer(asynUser*, void*)’:
../asynNDArrayDriver.cpp:492:20: error: ‘asynUser’ has no member named
‘timestamp’
         pasynUser->timestamp = myArray->epicsTS;
//home/pi/Apps/epics/base-3.14.12.6/configure/RULES_BUILD:221: recipe for
target 'asynNDArrayDriver.o' failed
make[4]: *** [asynNDArrayDriver.o] Error 1
//home/pi/Apps/epics/base-3.14.12.6/configure/RULES_ARCHS:61: recipe for
target 'install.linux-arm' failed
make[3]: *** [install.linux-arm] Error 2
//home/pi/Apps/epics/base-3.14.12.6/configure/RULES_DIRS:83: recipe for
target 'ADSrc.install' failed
make[2]: *** [ADSrc.install] Error 2
target 'ADApp.install' failed
make[1]: *** [ADApp.install] Error 2
target
'/home/pi/Apps/epics/synApps_5_6/support/areaDetector-master/ADCore.install'
failed
make: ***
[/home/pi/Apps/epics/synApps_5_6/support/areaDetector-master/ADCore.install]
Error 2
> Message: 1
> Date: Tue, 3 Jan 2017 14:21:24 +0000
> From: Mark Rivers <rivers@cars.uchicago.edu>
>       pixels
> Message-ID:
>       <70AE7462E7AD054C89DCBA45343D499A65DFB148@CARSMAIL2.CARS.APS.ANL.GOV>
> Content-Type: text/plain; charset="us-ascii"
> You are trying to build areaDetector 1-8-beta1, which is a very old
> version of areaDetector.  It probably won't work on the Raspberry Pi, it
> was never tested with linux-arm.
> I suggest you get the latest version from Github.
> https://github.com/areaDetector
> The installation instructions are here:
> https://github.com/areaDetector/areaDetector/blob/master/INSTALL_GUIDE.md
> Mark
> Sent: Monday, January 02, 2017 10:18 PM
> Subject: Installing areadetector on raspberry-pi2 OS raspbian pixels
>    Hi,
>   Can anyone please suggest me steps to install areadetector
> module on raspberry-pi having OS raspbian pixels.
>      I tried to follow this link https://prjemian.github.io/epicspi/
> but while making areadetector module I am getting errors.
> Here are the response for make
> '/home/pi/Apps/epics/synApps_5_6/support/dac128V-2-7/configure/O.linux-arm'
> perl /usr/local/epics/base/bin/linux-arm/convertRelease.pl checkRelease
> '/home/pi/Apps/epics/synApps_5_6/support/dac128V-2-7/configure'
> make -C ./dac128VApp install
> '/home/pi/Apps/epics/synApps_5_6/support/dac128V-2-7/dac128VApp'
> make -C ./src install
> '/home/pi/Apps/epics/synApps_5_6/support/dac128V-2-7/dac128VApp/src'
> '/home/pi/Apps/epics/synApps_5_6/support/dac128V-2-7/dac128VApp/src/O.linux-arm'
> '/home/pi/Apps/epics/synApps_5_6/support/dac128V-2-7/dac128VApp/Db'
> '/home/pi/Apps/epics/synApps_5_6/support/dac128V-2-7/dac128VApp/Db/O.linux-arm'
> '/home/pi/Apps/epics/synApps_5_6/support/dac128V-2-7'
> make -C /usr/local/epics/synApps_5_6/support/ip330-2-7 install
> '/home/pi/Apps/epics/synApps_5_6/support/ip330-2-7'
> '/home/pi/Apps/epics/synApps_5_6/support/ip330-2-7/configure'
> '/home/pi/Apps/epics/synApps_5_6/support/ip330-2-7/configure/O.linux-arm'
> make -C ./ip330App install
> '/home/pi/Apps/epics/synApps_5_6/support/ip330-2-7/ip330App'
> '/home/pi/Apps/epics/synApps_5_6/support/ip330-2-7/ip330App/src'
> '/home/pi/Apps/epics/synApps_5_6/support/ip330-2-7/ip330App/src/O.linux-arm'
> '/home/pi/Apps/epics/synApps_5_6/support/ip330-2-7/ip330App/Db'
> '/home/pi/Apps/epics/synApps_5_6/support/ip330-2-7/ip330App/Db/O.linux-arm'
> make -C /usr/local/epics/synApps_5_6/support/ipUnidig-2-9 install
> '/home/pi/Apps/epics/synApps_5_6/support/ipUnidig-2-9'
> '/home/pi/Apps/epics/synApps_5_6/support/ipUnidig-2-9/configure'
> '/home/pi/Apps/epics/synApps_5_6/support/ipUnidig-2-9/configure/O.linux-arm'
> make -C ./ipUnidigApp install
> '/home/pi/Apps/epics/synApps_5_6/support/ipUnidig-2-9/ipUnidigApp'
> '/home/pi/Apps/epics/synApps_5_6/support/ipUnidig-2-9/ipUnidigApp/src'
> '/home/pi/Apps/epics/synApps_5_6/support/ipUnidig-2-9/ipUnidigApp/src/O.linux-arm'
> '/home/pi/Apps/epics/synApps_5_6/support/ipUnidig-2-9/ipUnidigApp/Db'
> '/home/pi/Apps/epics/synApps_5_6/support/ipUnidig-2-9/ipUnidigApp/Db/O.linux-arm'
> make -C /usr/local/epics/synApps_5_6/support/love-3-2-5 install
> '/home/pi/Apps/epics/synApps_5_6/support/love-3-2-5'
> '/home/pi/Apps/epics/synApps_5_6/support/love-3-2-5/configure'
> '/home/pi/Apps/epics/synApps_5_6/support/love-3-2-5/configure/O.linux-arm'
> make -C ./loveApp install
> '/home/pi/Apps/epics/synApps_5_6/support/love-3-2-5/loveApp'
> '/home/pi/Apps/epics/synApps_5_6/support/love-3-2-5/loveApp/src'
> '/home/pi/Apps/epics/synApps_5_6/support/love-3-2-5/loveApp/src/O.linux-arm'
> '/home/pi/Apps/epics/synApps_5_6/support/love-3-2-5/loveApp/Db'
> '/home/pi/Apps/epics/synApps_5_6/support/love-3-2-5/loveApp/Db/O.linux-arm'
> make -C ./iocBoot install
> '/home/pi/Apps/epics/synApps_5_6/support/love-3-2-5/iocBoot'
> make -C ./ioclove install
> '/home/pi/Apps/epics/synApps_5_6/support/love-3-2-5/iocBoot/ioclove'
> make[3]: Nothing to be done for 'install'.
> make -C /usr/local/epics/synApps_5_6/support/ip-2-13 install
> '/home/pi/Apps/epics/synApps_5_6/support/ip-2-13'
> '/home/pi/Apps/epics/synApps_5_6/support/ip-2-13/configure'
> '/home/pi/Apps/epics/synApps_5_6/support/ip-2-13/configure/O.linux-arm'
> make -C ./ipApp install
> '/home/pi/Apps/epics/synApps_5_6/support/ip-2-13/ipApp'
> '/home/pi/Apps/epics/synApps_5_6/support/ip-2-13/ipApp/src'
> '/home/pi/Apps/epics/synApps_5_6/support/ip-2-13/ipApp/src/O.linux-arm'
> '/home/pi/Apps/epics/synApps_5_6/support/ip-2-13/ipApp/Db'
> '/home/pi/Apps/epics/synApps_5_6/support/ip-2-13/ipApp/Db/O.linux-arm'
> make -C /usr/local/epics/synApps_5_6/support/optics-2-8-1 install
> '/home/pi/Apps/epics/synApps_5_6/support/optics-2-8-1'
> '/home/pi/Apps/epics/synApps_5_6/support/optics-2-8-1/configure'
> '/home/pi/Apps/epics/synApps_5_6/support/optics-2-8-1/configure/O.linux-arm'
> make -C ./opticsApp install
> '/home/pi/Apps/epics/synApps_5_6/support/optics-2-8-1/opticsApp'
> '/home/pi/Apps/epics/synApps_5_6/support/optics-2-8-1/opticsApp/src'
> '/home/pi/Apps/epics/synApps_5_6/support/optics-2-8-1/opticsApp/src/O.linux-arm'
> '/home/pi/Apps/epics/synApps_5_6/support/optics-2-8-1/opticsApp/Db'
> '/home/pi/Apps/epics/synApps_5_6/support/optics-2-8-1/opticsApp/Db/O.linux-arm'
> make -C /usr/local/epics/synApps_5_6/support/stream-2-5-1 install
> '/home/pi/Apps/epics/synApps_5_6/support/stream-2-5-1'
> '/home/pi/Apps/epics/synApps_5_6/support/stream-2-5-1/configure'
> '/home/pi/Apps/epics/synApps_5_6/support/stream-2-5-1/configure/O.linux-arm'
> make -C ./streamDevice install
> '/home/pi/Apps/epics/synApps_5_6/support/stream-2-5-1/streamDevice'
> '/home/pi/Apps/epics/synApps_5_6/support/stream-2-5-1/streamDevice/src'
> '/home/pi/Apps/epics/synApps_5_6/support/stream-2-5-1/streamDevice/src/O.linux-arm'
> make -C ./srcSynApps install
> '/home/pi/Apps/epics/synApps_5_6/support/stream-2-5-1/streamDevice/srcSynApps'
> '/home/pi/Apps/epics/synApps_5_6/support/stream-2-5-1/streamDevice/srcSynApps/O.linux-arm'
> make -C ./streamApp install
> '/home/pi/Apps/epics/synApps_5_6/support/stream-2-5-1/streamDevice/streamApp'
> '/home/pi/Apps/epics/synApps_5_6/support/stream-2-5-1/streamDevice/streamApp/O.linux-arm'
> make -C /usr/local/epics/synApps_5_6/support/modbus-2-3 install
> '/home/pi/Apps/epics/synApps_5_6/support/modbus-2-3'
> '/home/pi/Apps/epics/synApps_5_6/support/modbus-2-3/configure'
> '/home/pi/Apps/epics/synApps_5_6/support/modbus-2-3/configure/O.linux-arm'
> make -C ./modbusApp install
> '/home/pi/Apps/epics/synApps_5_6/support/modbus-2-3/modbusApp'
> '/home/pi/Apps/epics/synApps_5_6/support/modbus-2-3/modbusApp/src'
> '/home/pi/Apps/epics/synApps_5_6/support/modbus-2-3/modbusApp/src/O.linux-arm'
> '/home/pi/Apps/epics/synApps_5_6/support/modbus-2-3/modbusApp/Db'
> '/home/pi/Apps/epics/synApps_5_6/support/modbus-2-3/modbusApp/Db/O.linux-arm'
> '/home/pi/Apps/epics/synApps_5_6/support/modbus-2-3/iocBoot'
> make -C ./iocTest install
> '/home/pi/Apps/epics/synApps_5_6/support/modbus-2-3/iocBoot/iocTest'
> make -C /usr/local/epics/synApps_5_6/support/vac-1-4 install
> '/home/pi/Apps/epics/synApps_5_6/support/vac-1-4'
> '/home/pi/Apps/epics/synApps_5_6/support/vac-1-4/configure'
> '/home/pi/Apps/epics/synApps_5_6/support/vac-1-4/configure/O.linux-arm'
> make -C ./vacApp install
> '/home/pi/Apps/epics/synApps_5_6/support/vac-1-4/vacApp'
> '/home/pi/Apps/epics/synApps_5_6/support/vac-1-4/vacApp/src'
> '/home/pi/Apps/epics/synApps_5_6/support/vac-1-4/vacApp/src/O.linux-arm'
> '/home/pi/Apps/epics/synApps_5_6/support/vac-1-4/vacApp/Db'
> '/home/pi/Apps/epics/synApps_5_6/support/vac-1-4/vacApp/Db/O.linux-arm'
> '/home/pi/Apps/epics/synApps_5_6/support/vac-1-4/iocBoot'
> make -C ./iocppc install
> '/home/pi/Apps/epics/synApps_5_6/support/vac-1-4/iocBoot/iocppc'
> make -C /usr/local/epics/synApps_5_6/support/softGlue-2-2 install
> '/home/pi/Apps/epics/synApps_5_6/support/softGlue-2-2'
> '/home/pi/Apps/epics/synApps_5_6/support/softGlue-2-2/configure'
> '/home/pi/Apps/epics/synApps_5_6/support/softGlue-2-2/configure/O.linux-arm'
> make -C ./softGlueApp install
> '/home/pi/Apps/epics/synApps_5_6/support/softGlue-2-2/softGlueApp'
> '/home/pi/Apps/epics/synApps_5_6/support/softGlue-2-2/softGlueApp/src'
> '/home/pi/Apps/epics/synApps_5_6/support/softGlue-2-2/softGlueApp/src/O.linux-arm'
> '/home/pi/Apps/epics/synApps_5_6/support/softGlue-2-2/softGlueApp/Db'
> '/home/pi/Apps/epics/synApps_5_6/support/softGlue-2-2/softGlueApp/Db/O.linux-arm'
> make -C /usr/local/epics/synApps_5_6/support/quadEM-2-6 install
> '/home/pi/Apps/epics/synApps_5_6/support/quadEM-2-6'
> '/home/pi/Apps/epics/synApps_5_6/support/quadEM-2-6/configure'
> '/home/pi/Apps/epics/synApps_5_6/support/quadEM-2-6/configure/O.linux-arm'
> make -C ./quadEMApp install
> '/home/pi/Apps/epics/synApps_5_6/support/quadEM-2-6/quadEMApp'
> '/home/pi/Apps/epics/synApps_5_6/support/quadEM-2-6/quadEMApp/src'
> '/home/pi/Apps/epics/synApps_5_6/support/quadEM-2-6/quadEMApp/src/O.linux-arm'
> '/home/pi/Apps/epics/synApps_5_6/support/quadEM-2-6/quadEMApp/Db'
> '/home/pi/Apps/epics/synApps_5_6/support/quadEM-2-6/quadEMApp/Db/O.linux-arm'
> make -C /usr/local/epics/synApps_5_6/support/delaygen-1-0-7 install
> '/home/pi/Apps/epics/synApps_5_6/support/delaygen-1-0-7'
> '/home/pi/Apps/epics/synApps_5_6/support/delaygen-1-0-7/configure'
> '/home/pi/Apps/epics/synApps_5_6/support/delaygen-1-0-7/configure/O.linux-arm'
> make -C ./delaygenApp install
> '/home/pi/Apps/epics/synApps_5_6/support/delaygen-1-0-7/delaygenApp'
> '/home/pi/Apps/epics/synApps_5_6/support/delaygen-1-0-7/delaygenApp/src'
> '/home/pi/Apps/epics/synApps_5_6/support/delaygen-1-0-7/delaygenApp/src/O.linux-arm'
> '/home/pi/Apps/epics/synApps_5_6/support/delaygen-1-0-7/delaygenApp/Db'
> '/home/pi/Apps/epics/synApps_5_6/support/delaygen-1-0-7/delaygenApp/Db/O.linux-arm'
> '/home/pi/Apps/epics/synApps_5_6/support/delaygen-1-0-7/iocBoot'
> make -C ./iocdelaygen install
> '/home/pi/Apps/epics/synApps_5_6/support/delaygen-1-0-7/iocBoot/iocdelaygen'
> make -C /usr/local/epics/synApps_5_6/support/camac-2-7 install
> '/home/pi/Apps/epics/synApps_5_6/support/camac-2-7'
> '/home/pi/Apps/epics/synApps_5_6/support/camac-2-7/configure'
> '/home/pi/Apps/epics/synApps_5_6/support/camac-2-7/configure/O.linux-arm'
> make -C ./camacApp install
> '/home/pi/Apps/epics/synApps_5_6/support/camac-2-7/camacApp'
> '/home/pi/Apps/epics/synApps_5_6/support/camac-2-7/camacApp/src'
> '/home/pi/Apps/epics/synApps_5_6/support/camac-2-7/camacApp/src/O.linux-arm'
> make -C ./devsrc install
> '/home/pi/Apps/epics/synApps_5_6/support/camac-2-7/camacApp/devsrc'
> '/home/pi/Apps/epics/synApps_5_6/support/camac-2-7/camacApp/devsrc/O.linux-arm'
> '/home/pi/Apps/epics/synApps_5_6/support/camac-2-7/camacApp/Db'
> '/home/pi/Apps/epics/synApps_5_6/support/camac-2-7/camacApp/Db/O.linux-arm'
> '/home/pi/Apps/epics/synApps_5_6/support/camac-2-7/iocBoot'
> make -C ./iocxxx install
> '/home/pi/Apps/epics/synApps_5_6/support/camac-2-7/iocBoot/iocxxx'
> make -C /usr/local/epics/synApps_5_6/support/mca-7-1 install
> '/home/pi/Apps/epics/synApps_5_6/support/mca-7-1'
> '/home/pi/Apps/epics/synApps_5_6/support/mca-7-1/configure'
> '/home/pi/Apps/epics/synApps_5_6/support/mca-7-1/configure/O.linux-arm'
> make -C ./mcaApp install
> '/home/pi/Apps/epics/synApps_5_6/support/mca-7-1/mcaApp'
> make -C ./mcaSrc install
> '/home/pi/Apps/epics/synApps_5_6/support/mca-7-1/mcaApp/mcaSrc'
> '/home/pi/Apps/epics/synApps_5_6/support/mca-7-1/mcaApp/mcaSrc/O.linux-arm'
> make -C ./CanberraSupport install
> '/home/pi/Apps/epics/synApps_5_6/support/mca-7-1/mcaApp/CanberraSupport'
> '/home/pi/Apps/epics/synApps_5_6/support/mca-7-1/mcaApp/CanberraSupport/O.linux-arm'
> make -C ./CanberraSrc install
> '/home/pi/Apps/epics/synApps_5_6/support/mca-7-1/mcaApp/CanberraSrc'
> '/home/pi/Apps/epics/synApps_5_6/support/mca-7-1/mcaApp/CanberraSrc/O.linux-arm'
> make -C ./SISSrc install
> '/home/pi/Apps/epics/synApps_5_6/support/mca-7-1/mcaApp/SISSrc'
> '/home/pi/Apps/epics/synApps_5_6/support/mca-7-1/mcaApp/SISSrc/O.linux-arm'
> make -C ./RontecSrc install
> '/home/pi/Apps/epics/synApps_5_6/support/mca-7-1/mcaApp/RontecSrc'
> '/home/pi/Apps/epics/synApps_5_6/support/mca-7-1/mcaApp/RontecSrc/O.linux-arm'
> '/home/pi/Apps/epics/synApps_5_6/support/mca-7-1/mcaApp/Db'
> '/home/pi/Apps/epics/synApps_5_6/support/mca-7-1/mcaApp/Db/O.linux-arm'
> '/home/pi/Apps/epics/synApps_5_6/support/mca-7-1/iocBoot'
> make -C ./iocCygwin install
> '/home/pi/Apps/epics/synApps_5_6/support/mca-7-1/iocBoot/iocCygwin'
> make -C ./iocRontec install
> '/home/pi/Apps/epics/synApps_5_6/support/mca-7-1/iocBoot/iocRontec'
> make -C ./iocVxWorks install
> '/home/pi/Apps/epics/synApps_5_6/support/mca-7-1/iocBoot/iocVxWorks'
> make -C ./iocLinux install
> '/home/pi/Apps/epics/synApps_5_6/support/mca-7-1/iocBoot/iocLinux'
> make -C /usr/local/epics/synApps_5_6/support/vme-2-8 install
> '/home/pi/Apps/epics/synApps_5_6/support/vme-2-8'
> '/home/pi/Apps/epics/synApps_5_6/support/vme-2-8/configure'
> '/home/pi/Apps/epics/synApps_5_6/support/vme-2-8/configure/O.linux-arm'
> make -C ./vmeApp install
> '/home/pi/Apps/epics/synApps_5_6/support/vme-2-8/vmeApp'
> '/home/pi/Apps/epics/synApps_5_6/support/vme-2-8/vmeApp/src'
> '/home/pi/Apps/epics/synApps_5_6/support/vme-2-8/vmeApp/src/O.linux-arm'
> '/home/pi/Apps/epics/synApps_5_6/support/vme-2-8/vmeApp/Db'
> '/home/pi/Apps/epics/synApps_5_6/support/vme-2-8/vmeApp/Db/O.linux-arm'
> make -C /usr/local/epics/synApps_5_6/support/areaDetector-1-8beta1 install
> '/home/pi/Apps/epics/synApps_5_6/support/areaDetector-1-8beta1'
> '/home/pi/Apps/epics/synApps_5_6/support/areaDetector-1-8beta1/configure'
> '/home/pi/Apps/epics/synApps_5_6/support/areaDetector-1-8beta1/configure/O.linux-arm'
> '/home/pi/Apps/epics/synApps_5_6/support/areaDetector-1-8beta1/ADApp'
> '/home/pi/Apps/epics/synApps_5_6/support/areaDetector-1-8beta1/ADApp/ADSrc'
> '/home/pi/Apps/epics/synApps_5_6/support/areaDetector-1-8beta1/ADApp/ADSrc/O.linux-arm'
> '/home/pi/Apps/epics/synApps_5_6/support/areaDetector-1-8beta1/ADApp/netCDFSrc'
> '/home/pi/Apps/epics/synApps_5_6/support/areaDetector-1-8beta1/ADApp/netCDFSrc/O.linux-arm'
> make -C ./cbfSrc install
> '/home/pi/Apps/epics/synApps_5_6/support/areaDetector-1-8beta1/ADApp/cbfSrc'
> '/home/pi/Apps/epics/synApps_5_6/support/areaDetector-1-8beta1/ADApp/cbfSrc/O.linux-arm'
> make -C ./prosilicaSupport install
> '/home/pi/Apps/epics/synApps_5_6/support/areaDetector-1-8beta1/ADApp/prosilicaSupport'
> '/home/pi/Apps/epics/synApps_5_6/support/areaDetector-1-8beta1/ADApp/prosilicaSupport/O.linux-arm'
> make -C ./tiffSupport install
> '/home/pi/Apps/epics/synApps_5_6/support/areaDetector-1-8beta1/ADApp/tiffSupport'
> '/home/pi/Apps/epics/synApps_5_6/support/areaDetector-1-8beta1/ADApp/tiffSupport/O.linux-arm'
> make -C ./hdf5Support install
> '/home/pi/Apps/epics/synApps_5_6/support/areaDetector-1-8beta1/ADApp/hdf5Support'
> '/home/pi/Apps/epics/synApps_5_6/support/areaDetector-1-8beta1/ADApp/hdf5Support/O.linux-arm'
> '/home/pi/Apps/epics/synApps_5_6/support/areaDetector-1-8beta1/ADApp/nexusSrc'
> '/home/pi/Apps/epics/synApps_5_6/support/areaDetector-1-8beta1/ADApp/nexusSrc/O.linux-arm'
> make -C ./pvcamSupport install
> '/home/pi/Apps/epics/synApps_5_6/support/areaDetector-1-8beta1/ADApp/pvcamSupport'
> '/home/pi/Apps/epics/synApps_5_6/support/areaDetector-1-8beta1/ADApp/pvcamSupport/O.linux-arm'
> make -C ./perkinElmerSupport install
> '/home/pi/Apps/epics/synApps_5_6/support/areaDetector-1-8beta1/ADApp/perkinElmerSupport'
> '/home/pi/Apps/epics/synApps_5_6/support/areaDetector-1-8beta1/ADApp/perkinElmerSupport/O.linux-arm'
> make -C ./magickSupport install
> '/home/pi/Apps/epics/synApps_5_6/support/areaDetector-1-8beta1/ADApp/magickSupport'
> '/home/pi/Apps/epics/synApps_5_6/support/areaDetector-1-8beta1/ADApp/magickSupport/O.linux-arm'
> make -C ./pluginSrc install
> '/home/pi/Apps/epics/synApps_5_6/support/areaDetector-1-8beta1/ADApp/pluginSrc'
> '/home/pi/Apps/epics/synApps_5_6/support/areaDetector-1-8beta1/ADApp/pluginSrc/O.linux-arm'
> make -C ./simDetectorSrc install
> '/home/pi/Apps/epics/synApps_5_6/support/areaDetector-1-8beta1/ADApp/simDetectorSrc'
> '/home/pi/Apps/epics/synApps_5_6/support/areaDetector-1-8beta1/ADApp/simDetectorSrc/O.linux-arm'
> make[4]: *** No rule to make target
> '../../../lib/linux-arm/libGraphicsMagick.a', needed by 'simDetectorApp'.
> Stop.
> /usr/local/epics/base/configure/RULES_ARCHS:61: recipe for target
> /usr/local/epics/base/configure/RULES_DIRS:83: recipe for target
> 'simDetectorSrc.install' failed
> make[2]: *** [simDetectorSrc.install] Error 2
> '/usr/local/epics/synApps_5_6/support/areaDetector-1-8beta1.install'
> failed
> make: ***
> [/usr/local/epics/synApps_5_6/support/areaDetector-1-8beta1.install] Error
> 2
> With Best Regards,
> Avanish Ojha
> Message: 2
> Date: Tue, 3 Jan 2017 14:36:00 +0000
> From: "Kasemir, Kay" <kasemirk@ornl.gov>
> To: lzf neu <lzfneu@live.com>
> Cc: "tech-talk@aps.anl.gov" <Tech-talk@aps.anl.gov>
> Subject: Re: Question about CSS Data Browser plot
> Message-ID: <11998B0A-B8C3-4398-9144-15DBCCD2E5F2@ornl.gov>
> Content-Type: text/plain; charset="utf-8"
> Hi:
> This  type of behavior can happen when your IOCs don?t have the correct
> time.
> Check if ?camonitor ..? reports good time stamps for the PVs from your
> IOCs.
> -Kay
> On Dec 29, 2016, at 11:06 AM, lzf neu
> <lzfneu@live.com<mailto:lzfneu@live.com>> wrote:
> hi all,
> When added pv name to Data Browser plot window, the plot line vs. time
> showed the right curve, but immediately changed into straight one which is
> not the right display. The line should fluctuate vs time. The time span I
> set is 1 hour. If I increase the time span, the line is still a straight
> one.
> however, the exported data is right from data browser plot and fluctuate
> vs time.
> I wonder what is wrong with my settings. The operation system is
> fedora25-64bit and CSS is unzipped from
> sns-css-4.1.1-linux.gtk.x86_64.zip.
> I have attatched the plot in the attatchment. Thanks in advance.
> <aaa.png>
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL:
> <http://mailman.aps.anl.gov/pipermail/tech-talk/attachments/20170103/32e47f9e/attachment.html>
> Message: 3
> Date: Tue, 3 Jan 2017 15:01:48 +0000
> From: <mark.heron@diamond.ac.uk>
> To: <tech-talk@aps.anl.gov>
> Subject: EPICS core development role at Diamond Light Source
> Message-ID: <AD1BB40A7457F5419F99609AD5B4CA92BA51253D@exchmbx03>
> Hello All,
> Diamond light source is one of the larger EPICS installations, having
> deployed EPICS for machine, photon beamline and detector control. As
> result we have a strong interest in the ongoing and successful development
> of EPICS and so have been actively contributing to the core development of
> EPICS at number of levels; including participating in the development of
> EPICS Version 4. We now have a vacancy for a developer to work on aspects
> of core EPICS developments, including EPICS Version 4. The role is
> expected to work closely with the other EPICS developers in defining
> future direction and taking on agreed work packages.  It will also be
> expected to represent Diamond in these developments and to contribute to
> developers' meetings and workshops. In undertaking this, there is full
> support from Diamond for travel etc.
> If this is a role which is of interest and you would like to discuss
> further, please feel free to contact myself.
> This vacancy is now listed on
> http://www.diamond.ac.uk/Careers/Vacancies/All/0114_16_NH.html with a
> closing date of 31/1/17.
> Regards.
> Mark Heron
> This e-mail and any attachments may contain confidential, copyright and or
> privileged material, and are for the use of the intended addressee only.
> If you are not the intended addressee or an authorised recipient of the
> addressee please notify us of receipt by returning the e-mail and do not
> use, copy, retain, distribute or disclose the information in or attached
> to the e-mail.
> Any opinions expressed within this e-mail are those of the individual and
> not necessarily of Diamond Light Source Ltd.
> Diamond Light Source Ltd. cannot guarantee that this e-mail or any
> attachments are free from viruses and we cannot accept liability for any
> damage which you may sustain as a result of software viruses which may be
> transmitted in or with the message.
> Diamond Light Source Limited (company no. 4375679). Registered in England
> and Wales with its registered office at Diamond House, Harwell Science and
> Innovation Campus, Didcot, Oxfordshire, OX11 0DE, United Kingdom
> A non-text attachment was scrubbed...
> Type: application/ms-tnef
> Desc: not available
> URL:
> <http://mailman.aps.anl.gov/pipermail/tech-talk/attachments/20170103/ae94e34c/attachment.bin>
> Tech-talk mailing list Tech-talk@aps.anl.gov
> https://mailman.aps.anl.gov/mailman/listinfo/tech-talk
> End of Tech-talk Digest, Vol 11, Issue 5
RE: Installing areadetector on raspberry-pi2 OS raspbian pixels avanish
Prev: Re: Default value to field SCAN Dirk Zimoch
Next: multiple include not supprted with EPICS 3.15.2 haquin
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Prev: RE: Installing areadetector on raspberry-pi2 OS raspbian pixels avanish
ANJ, 14 Feb 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
