1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Question about "Link A array too large"
To: lzf neu <[email protected]>
Date: Thu, 29 Dec 2016 18:55:20 +0000
What version of EPICS base, asyn, and modbus are you using? I cannot find any error messages in base 3.14.12.5 that contain the string "array too large". Is that the exact error message you are getting? Since you are getting a core dump you can run gdb on the core file to see exactly where it is crashing.
Sent from my iPhone
> On Dec 28, 2016, at 9:15 AM, lzf neu <[email protected]> wrote:
> Hi all,
> I want to read real-time dose value from the radiation monitor by using epics. The driver is modbus and asyn.
> However,when starting epics ioc in server, I encounter a problem, the terminal displays something like the following information:
> Link A array too large..
> Link B array too large..
> Link L array too large...
> Segment fault(core dump)
> The operation system used in server is fedora20 64bit. However, the same operation system and the same modbus and asyn driver works well in my laptop connected to the monitor.
> Could you give me some suggestions to solve the problem, thanks in advanced.
Re: Question about "Link A array too large" Michael Davidsaver
答复: Question about "Link A array too large" lzf neu
Prev: Re: Asyn support Mark Rivers
Next: Re: Question about "Link A array too large" Michael Davidsaver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Question about "Link A array too large" Hugo Slepicka
ANJ, 29 Dec 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
