Using asyn will make developing a driver easier, but in most cases you can use StreamDevice (a separate install which works with asyn) and you only then need
to provide a text based protocol definition file for new devices. See
http://www.aps.anl.gov/epics/modules/soft/asyn/ for links to versions of asyn compatible with your EPICS base as well as links to using SteamDevice. If you will be installing other EPICS modules too, you may want to consider the synApps collection
https://www1.aps.anl.gov/BCDA/synApps which includes asyn and StreamDevice as well as many other useful EPICS modules
Freddie
On Behalf Of Stefen Paul
Sent: 27 December 2016 07:14
To: EPICS Tech Talk
Subject: Asyn support
Hi All,
I have downloaded and built epics base 3.14.12.4 for windows, on a PC running winXP.
I wanna use serial COM ports from epics application. I believe I will be needing asyn support to make that happen.
plz suggest which asyn version will work with my epics version, how to integrate asyn in my setup and how to use it in application.
- Re: Asyn support Mark Rivers
- Asyn support Stefen Paul
All PV dosconnect in css-BPY Paramveer Jain
Question about CSS Data Browser plot lzf neu
<2016>
<2016>
ANJ, 29 Dec 2016 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
