Subject: |
Having trooble setting up CSS archive engine with mySQL |
David Michel <[email protected]> |
To: |
EPICS mailing list <[email protected]> |
Date: |
Mon, 12 Dec 2016 11:13:46 +0000 |
Hi All,
I'm currently trying to setup the CSS archiver engine with MySQL and seeing this error when running the ArchiveConfigTool:
./ArchiveConfigTool -pluginCustomization ~/archiver/ArchiveConfigTool/plugin_customization.ini -replace_engine -engine clf_dipole -config ~/archiver/ArchiveConfigTool/example_engineConfiguration.xml -import Importing : /home/swdev/archiver/ArchiveConfigTool/example_engineConfiguration.xml 2016-12-12 10:52:10.473 SEVERE [Thread 1] org.csstudio.archive.config.rdb.ArchiveConfigApplication (start) - Exception com.mysql.jdbc.exceptions.jdbc4.CommunicationsException: Communications link failure The last packet sent successfully to the server was 0 milliseconds ago. The driver has not received any packets from the server.
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method) at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:57) at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45) at java.lang.reflect.Constructor.newInstance(Constructor.java:526) at com.mysql.jdbc.Util.handleNewInstance(Util.java:411) at com.mysql.jdbc.SQLError.createCommunicationsException(SQLError.java:1116) at com.mysql.jdbc.MysqlIO.<init>(MysqlIO.java:344) at com.mysql.jdbc.ConnectionImpl.coreConnect(ConnectionImpl.java:2332) at com.mysql.jdbc.ConnectionImpl.connectOneTryOnly(ConnectionImpl.java:2369) at com.mysql.jdbc.ConnectionImpl.createNewIO(ConnectionImpl.java:2153) at com.mysql.jdbc.ConnectionImpl.<init>(ConnectionImpl.java:792) at com.mysql.jdbc.JDBC4Connection.<init>(JDBC4Connection.java:47) at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method) at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:57) at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45) at java.lang.reflect.Constructor.newInstance(Constructor.java:526) at com.mysql.jdbc.Util.handleNewInstance(Util.java:411) at com.mysql.jdbc.ConnectionImpl.getInstance(ConnectionImpl.java:381) at com.mysql.jdbc.NonRegisteringDriver.connect(NonRegisteringDriver.java:305) at java.sql.DriverManager.getConnection(DriverManager.java:571) at java.sql.DriverManager.getConnection(DriverManager.java:187) at org.csstudio.platform.utility.rdb.internal.MySQL_RDB.connect(MySQL_RDB.java:55) at org.csstudio.platform.utility.rdb.RDBUtil.<init>(RDBUtil.java:179) at org.csstudio.platform.utility.rdb.RDBUtil.connect(RDBUtil.java:143) at org.csstudio.archive.config.rdb.RDBArchiveConfig.<init>(RDBArchiveConfig.java:80) at org.csstudio.archive.config.rdb.XMLImport.<init>(XMLImport.java:123) at org.csstudio.archive.config.rdb.ArchiveConfigApplication.start(ArchiveConfigApplication.java:206) at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:606) at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622) at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577) at org.eclipse.equinox.launcher.Main.run(Main.java:1410) at org.eclipse.equinox.launcher.Main.main(Main.java:1386) Caused by: java.net.ConnectException: Connection refused at java.net.PlainSocketImpl.socketConnect(Native Method) at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:339) at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:200) at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:182) at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392) at java.net.Socket.connect(Socket.java:579) at java.net.Socket.connect(Socket.java:528) at java.net.Socket.<init>(Socket.java:425) at java.net.Socket.<init>(Socket.java:241) at com.mysql.jdbc.StandardSocketFactory.connect(StandardSocketFactory.java:257) at com.mysql.jdbc.MysqlIO.<init>(MysqlIO.java:294)
So, looks like it cannot connect to the database.... although it is running:
start: Job is already running: mysql
I've just installed mysql (14.14) on my ubuntu machine with apt-get. All I did what set up the root password, create the archive and report user and run the schema with mysql> source ./mysql_schema.txt;
11 rows in set (0.00 sec)
I have set the database ip, port and db user/password in the plugin_customization.ini as such:
org.csstudio.archive.rdb/url="" href="http://192.168.41.3:3306/archive">192.168.41.3:3306/archive org.csstudio.archive.rdb/user=archive org.csstudio.archive.rdb/password=archive
I'm probably missing an obvious step here.... any help would be greatly appreciated! Thanks! David
- Re: Having trooble setting up CSS archive engine with mySQL Kasemir, Kay
CSS Beast mail notification Benjamin Hetz
Re: 答复: 答复: MVME5500 and turbo-pmac-vme-ultralite Ron Sluiter
<2016>
<2016>
ANJ, 12 Dec 2016 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
