1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Epics V4 Questions - New to Epics 4
To: [email protected]
Date: Tue, 6 Dec 2016 07:08:57 -0500
On 12/05/2016 05:45 PM, Madden, Timothy J. wrote:
I am getting started with Epics V4.
I am playing with the examples in the Java version of 4.6.
Specifically I am using ExampleDatabase.java.
Say we wish to make PVs that are more than soft PVs. There seems to be more than one way to
make a PV do something. Example: We put a 1 to an int PV, and the server writes something to an instrument.
How do we do this? It seems like there are several ways:
1) Use a monitor client like seq does.
2) extend PVRecord and fill in the process() function. Not sure how to get all the data we need.
3) use this RPC business, extending a PVRecord.
4) What about adding a PVListener to PVRecord? I could not figure this out. The idea is that PVListener
would make the instrument do something, and we need not extend PVRecord.
What is the preferred design for making a PV do something in a server?
If  you want client to access your server via channelRPC then 4)
For the client to  access your server via channelGet, ... , channelPutGet then 2)
4) should not be used by You. It is use by internal implementation to support returning only fields that change to the client.
For channelRPC look at exampleJava/hellloRPC.
It has both an exampleServer and an exampleClient.
For a client to use channelPutGet look at
exampleJava/examplePutGet
It has both HelloPutGetRecord and HelloPutGetRecord
Note how HelloPutGetRecord
1) creates a PVStructure that has the fields it needs.
2) creates a PVRecord that has the newly created pvStructure as it's top level PVStructure.
3) implements method process.
Note that channelGet, channelPut, and monitors will also work with this example.
For example a client could first do a channelPut to cause the record to process and then a channelGet to get the result.
exampleJava/database also shows how to implement both HelloPutGetRecord and hellloRPC as part of a database that has other PVRecords.
You want to
Start with HelloPutGetRecord and implement something like
public class ExampleIntRecord extends PVRecord {
    private static final FieldCreate fieldCreate = FieldFactory.getFieldCreate();
    private static final PVDataCreate pvDataCreate = PVDataFactory.getPVDataCreate();
    private static final StandardField standardField = StandardFieldFactory.getStandardField();
    private PVInt pvValue;
    private PVStructure pvAlarm;
    public static PVRecord create(String recordName)
       NTScalarBuilder ntScalarBuilder = NTScalar.createBuilder();
        PVStructure pvStructure = ntScalarBuilder.
                value(ScalarType.pvInt).
                addAlarm().
                addTimeStamp().
                createPVStructure();
        PVRecord pvRecord = new ExampleIntRecord(recordName,pvDataCreate.createPVStructure(structure));
        PVDatabase master = PVDatabaseFactory.getMaster();
        master.addRecord(pvRecord);
        return pvRecord;
    private ExampleIntRecord(String recordName,PVStructure pvStructure) {
        super(recordName,pvStructure);
        pvValue = pvStructure.getSubField(PVInt.class, "value");
        if(pvValue==null) throw new IllegalArgumentException("value not found");
       pvAlarm = pvStructure.getSubField(PVStructure.class, "alarm");
        if(pvAlarm==null) throw new IllegalArgumentException("alarm not found");
    public void process()
        int value = pvValue.get();
        // You do  something with value !!!
        super.process();
Note that You can use the alarm field to report problem if the client send a bad value.
General question:
 I know RPC stanhs for remote procedure call, but what does it mean in epics V4?
channelPutGet and channelRPC both implement a remote procedure call where all data is passed as PVData.
For both the client sends a PVStructure to the server.
The server processes the request and returns the result via a PVStructure.
For a channelRPC there is no actual PVRecord that can be accessed via channelGet, ..., monitor.
For channelPutGet there is a PVRecord with a PVStructure with the introspection interface
structure
    argument
    result
The client sends data that matches argument and the server returns data that matches result.
Other client can get and put and monitor data in the PVRecord.
Marty
What does it do that epics V3 does not do? Is this just a fancy name for record support?
Tim Madden
APS, Argonne
Epics V4 Questions - New to Epics 4 Madden, Timothy J.
Prev: RE: deadlock in pcas 3.14.12.6-rc1 Wang Xiaoqiang (PSI)
Next: RE: streamdevice 2.7.7 and PINI Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Epics V4 Questions - New to Epics 4 Andrew Johnson
Next: Re: Epics V4 Questions - New to Epics 4 Ralph Lange
ANJ, 06 Dec 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
