1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Capturing data from string which is sent by device
Date: Mon, 5 Dec 2016 08:13:56 -0800
Those look like they might be RFC 2217 remote serial port configuration.  Try specifying the COM option to the IP address argument to the ASYN port configuration command.
On Dec 5, 2016, at 7:40 AM, Mark Rivers <[email protected]> wrote:
I have read the manual for the MPC that you sent.  Indeed it should never sent the unprintable characters like \377\372.  I see that you are using a TCP connection to the MPC, which means you are using its internal Lantronix terminal server.  I think you may have some setting on the Lantronix wrong, for example the start bits, stop bits, or parity.  Can you open a Web page to the Lantronix and see what settings you are using?
Eric Norum
[email protected]
RE: Capturing data from string which is sent by device Mark Rivers
Prev: RE: Capturing data from string which is sent by device Mark Rivers
Next: IOC segfaults with epicsMutexLock (pmutexNode=0x0) Blaz Kranjc
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Next: Operational experience for Keithley 6485/6487 Sapozhnikov, Leonid
ANJ, 05 Dec 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
