Hi Matt and Ben, ----- On 1 Dec, 2016, at 21:41, Matt Newville <[email protected]> wrote:
In the SNL global entry block, which is called once, when the sequencer starts up, I do all the Python bindings: For example, I initialise my "handle" structure members (such as "PyObject * pFuncText "): // pFuncText is also a borrowed reference elogbook->pFuncText = PyDict_GetItemString(elogbook->pDict, (char*)"createOlogEntry"); //pClient would be null if the Python syntax is wrong, for example if (elogbook->pFuncText == NULL) { if (PyErr_Occurred()) { PyErr_Print(); elogbook->initialised = 0; log_error("Failed to get logbook createOlogEntry function"); log_python_error(); return -3; } } Then, in the API that is re-used by the SNL (i.e. in a particular state "entry" block), I use the structures created: /* * Write a text message to the logbook handle. * * Parameters: * log_handle = handle from call to elogbook_open. * * Returns 0 on success. * -1 = input parameter error * -2 = invalid handle * -3 = handle not initialised. * -4 = Other Python error */ int elogbook_log_text (int log_handle, const char *text){ // sanity checking - allow to be called with invalid handle. .. snip .. PyObject *pArgs, *pValue, *pText; //Build a tuple to hold my arguments pText = PyString_FromString(text); pArgs = PyTuple_New(2); PyTuple_SetItem(pArgs, 0, elogbook->pObjLogbook); PyTuple_SetItem(pArgs, 1, pText); //Call createOlogEntry function, passing it the input text pValue = PyObject_CallObject(elogbook->pFuncText, pArgs); if (pValue == NULL) { if (PyErr_Occurred()) { PyErr_Print(); log_error("Call to createOlogEntry from elogbook_log_text failed"); log_python_error(); return -4; } log_error("Call to createOlogEntry returned NULL instead of return code"); result = -4; } else { result = (int)PyLong_AsLong(pValue); Py_DECREF(pValue); } return result; }
I don't use any such context calls. The Python in question just does things like: import epics ... snip ... ''' Create a new entry in the logbook from SUP POS status''' def createOlogPOSPulseEndEntry(logbook, status, write_elog=1): Id = epics.caget('CTRL:PULSE-ID', as_string=True) StartTime = epics.caget('CTRL-SUP-TIME:T0-HR', as_string=True) EndTime = epics.caget('CTRL-SUP-TIME:TEND-HR', as_string=True) ..snip... Should I be doing anything different with ca contexts in the Python code??
Good question: I will look into that...
Well, my SNL is generated from Enterprise Architect XMI via an XSLT .. I *could* craft an XMI to Python XSLT, too!! :D Regards, Kevin -- Kevin Meyer Cosylab, Ljubljana, Slovenia Telephone: +386-(0)1-320-47-82 Mobile: +386-(0)70-260-321
ANJ, 02 Dec 2016 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
