Hello folks, As a very part-time recreational user of EPICS (really only with Mark Rivers' MCA application), you will have to excuse an unhealthy amount of ignorance that is sure to besmirch the ensuing concern of mine. With that disclaimer out of the way... I am trying to install the MCA application, its required modules, and EPICS R3.15.5 on a Windows 10 64-bit PC. When attempting to build the sscan module, required by MCA, the errors below are produced, beginning with the inability to find tsDefs.h (it does not exist in R3.15). I'm aware that sscan is not explicitly said to be compatible with R3.15, but only R3.14. And that is probably why the tsDefs.h error arises. My question to knowledgeable users is whether there might be a simple fix (commenting out the tsDefs.h line?) or whether my only realistic option is to install the older EPICS base. Thanks, Carl Willis 505-412-3277 saveData_writeXDR.c ../saveData_writeXDR.c(200): fatal error C1083: Cannot open include file: 'tsDefs.h': No such file or directory c:\epics\base/configure/RULES_BUILD:229: recipe for target 'saveData_writeXDR.obj' failed make[3]: *** [saveData_writeXDR.obj] Error 2 make[3]: Leaving directory 'C:/epics/support/sscan-2-10/sscanApp/src/O.windows-x64' c:\epics\base/configure/RULES_ARCHS:58: recipe for target 'install.windows-x64' failed make[2]: *** [install.windows-x64] Error 2 make[2]: Leaving directory 'C:/epics/support/sscan-2-10/sscanApp/src' c:\epics\base/configure/RULES_DIRS:84: recipe for target 'src.install' failed make[1]: *** [src.install] Error 2 make[1]: Leaving directory 'C:/epics/support/sscan-2-10/sscanApp' c:\epics\base/configure/RULES_DIRS:84: recipe for target 'sscanApp.install' failed make: *** [sscanApp.install] Error 2
ANJ, 30 Nov 2016 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
