HI all, I used the epics 3.14.15.2, synapps5.8 and centos 7_64. I have used the motor module successfully. Now I am trying to add the sscan module. I tried to do some change in my st.cmd as the sscanDoc.html said, but I did not get the point. This is my st.cmd.( motor move is ok) --------------------------------------------- # The is the ASYN example for communication to a ARIES. # "#!" marks lines that can be uncommented. < envPaths dbLoadDatabase("$(TOP)/dbd/WithAsyn.dbd") WithAsyn_registerRecordDeviceDriver(pdbbase) dbLoadTemplate("motor.substitutions.ARIES.test") dbLoadRecords("$(TOP)/db/motorUtil.db", "P=KTG:") # The following commands are for a local serial line # Configure the asyn server code for either sun or linux. #!Sun Solaris !drvAsynSerialPortConfigure("L0","/dev/ttya" ,0,0,0) #!Redhat Linux!drvAsynSerialPortConfigure("L0","/dev/ttyS0",0,0,0) drvAsynIPPortConfigure("L0","192.168.1.120:12321",0,0,0) # Kohzu ARIES motor controller setup parameters: # (1) maximum number of controllers in system # (2) motor task polling rate (min=1Hz,max=60Hz) ARIESSetup(4, 5) # Kohzu ARIES motor controller configuration parameters: # (1) controller# being configured # (2) ASYN port name # (3) address (GPIB only) ARIESConfig(0, "L0", 0) var drvARIESdebug 4 ########## sscan set ############### dbLoadRecords("$(SSCAN)/sscanApp/Db/standardScans.db","P=KTG:,MAXPTS1=1000,MAXPTS2=1000,MAXPTS3=1000,MAXPTS4=1000,MAXPTSH=1000") dbLoadRecords("$(SSCAN)/sscanApp/Db/saveData.db","P=KTG:") dbLoadRecords("$(SSCAN)/sscanApp/Db/scanProgress.db","P=KTG:") #dbLoadTemplate("scanParms.substitutions") ################################## iocInit # motorUtil (allstop & alldone) motorUtilInit("KTG:") saveData_Init("saveData.req", "P=KTG:") --------------------------------------------------------------------- This is the output: [root@localhost iocWithAsyn]# ../../bin/linux-x86_64/WithAsyn st.cmd.ARIES.test Successfully locked memory using mlockAll # The is the ASYN example for communication to a ARIES. # "#!" marks lines that can be uncommented. < envPaths epicsEnvSet("ARCH","linux-x86_64") epicsEnvSet("IOC","iocWithAsyn") epicsEnvSet("TOP","/opt/synApps_5_8/support/motor-6-9") epicsEnvSet("SUPPORT","/opt/synApps_5_8/support") epicsEnvSet("ASYN","/opt/synApps_5_8/support/asyn-4-26") epicsEnvSet("SNCSEQ","/opt/synApps_5_8/support/seq-2-2-3") epicsEnvSet("BUSY","/opt/synApps_5_8/support/busy-1-6-1") epicsEnvSet("EPICS_BASE","/opt/base") epicsEnvSet("IPAC","/opt/synApps_5_8/support/ipac-2-13") epicsEnvSet("SSCAN","/opt/synApps_5_8/support/sscan-2-10-1") epicsEnvSet("AUTOSAVE","/opt/synApps_5_8/support/autosave-5-6-1") epicsEnvSet("STREAM","/opt/synApps_5_8/support/stream-2-6a") dbLoadDatabase("/opt/synApps_5_8/support/motor-6-9/dbd/WithAsyn.dbd") WithAsyn_registerRecordDeviceDriver(pdbbase) dbLoadTemplate("motor.substitutions.ARIES.test") dbLoadRecords("/opt/synApps_5_8/support/motor-6-9/db/motorUtil.db", "P=KTG:") # The following commands are for a local serial line # Configure the asyn server code for either sun or linux. #!Sun Solaris !drvAsynSerialPortConfigure("L0","/dev/ttya" ,0,0,0) #!Redhat Linux!drvAsynSerialPortConfigure("L0","/dev/ttyS0",0,0,0) #drvAsynSerialPortConfigure("L0","/dev/ttyUSB0" ,0,0,0) #asynSetOption("L0", -1, "baud", "38400") #asynSetOption("L0", -1, "bits", "8") #asynSetOption("L0", -1, "parity", "none") #asynSetOption("L0", -1, "stop", "1") #asynSetOption("L0", -1, "clocal", "Y") #asynSetOption("L0", -1, "crtscts", "N") drvAsynIPPortConfigure("L0","192.168.1.120:12321",0,0,0) # Kohzu ARIES motor controller setup parameters: # (1) maximum number of controllers in system # (2) motor task polling rate (min=1Hz,max=60Hz) ARIESSetup(4, 5) # Kohzu ARIES motor controller configuration parameters: # (1) controller# being configured # (2) ASYN port name # (3) address (GPIB only) ARIESConfig(0, "L0", 0) var drvARIESdebug 4 ########## sscan set ############### dbLoadRecords("/opt/synApps_5_8/support/sscan-2-10-1/sscanApp/Db/standardScans.db","P=KTG:,MAXPTS1=1000,MAXPTS2=1000,MAXPTS3=1000,MAXPTS4=1000,MAXPTSH=1000") Record "KTG:scan1" is of unknown type "sscan" Error at or before ")" in file "/opt/synApps_5_8/support/sscan-2-10-1/sscanApp/Db/standardScans.db" line 126 Error: syntax error dbLoadRecords("/opt/synApps_5_8/support/sscan-2-10-1/sscanApp/Db/saveData.db","P=KTG:") dbLoadRecords("/opt/synApps_5_8/support/sscan-2-10-1/sscanApp/Db/scanProgress.db","P=KTG:") #dbLoadTemplate("scanParms.substitutions") ################################## asynSetTraceIOMask("L0",-1,0x9) iocInit Starting iocInit ############################################################################ ## EPICS R3.15.2 $Date: Thu 2015-05-14 14:09:28 +0200$ ## EPICS Base built Oct 16 2016 ############################################################################ iocRun: All initialization complete # motorUtil (allstop & alldone) motorUtilInit("KTG:") saveData_Init("saveData.req", "P=KTG:") st.cmd.ARIES.test line 52: Command saveData_Init not found. epics> Regards, lynn
ANJ, 29 Nov 2016 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
