1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: MEDEM sexagesimal number format
Date: Tue, 29 Nov 2016 08:06:36 +0000
Hi all,
I'm testing the sexagesimal number format in MEDEM, but I'm experiencing a
strange behaviour.
I have defined an ao PV named AAA with and MEDEM Text Entry with sexagesimal
number format. In a terminal window I'm monitoring the AAA PV with camonitor.
As soon as I set in MEDEM the sexagesimal value 12:34:56.789 the PV assumes the
correct value, but immediately the value changes to something approximated.
This is the camonitor output:
$ camonitor -f16 AAA
AAA                            2016-11-28 17:24:05.143777 0.0000000000000000
AAA                            2016-11-28 17:24:18.312258 12.5824413888888884
AAA                            2016-11-28 17:24:18.312329 12.5824409999999993
As soon as the PV gets it last value, the MEDEM Text Entry modifies it content
to 12:34:56.787599999997. It seems that MEDEM applies some correction to the
read-back value during conversion back to sexagesimal format (and looking MEDEM
source code indeed this is the case, but only to avoid string manipulation due
to reminders, this modified value is discarded after sexagesimal string
conversion).
I'm testing converted values also with this online converter:
http://www.astrosurf.com/astronosur/conversion.htm
I'm asking this because I'm porting this feature to CSS (CSS team, a patch will
follow soon :) and I'm having the very same behavior also with CSS.
Luca
<< Le informazioni contenute in questo messaggio di posta elettronica e relativi allegati sono riservate e confidenziali e ne è vietata la diffusione in qualunque modo eseguita. Qualora Lei non fosse la persona a cui il presente messaggio è destinato, La invitiamo ad eliminarlo e a darcene gentile comunicazione. Quanto precede ai fini del rispetto delle Legge 675/96 e del Decreto Legislativo 30/06/2003 n.196, sulla tutela dei dati personali >>
<< This e-mail is confidential and may well also be legally privileged. If you have received it in error, you are on notice of its status. Please notify us immediately by reply e-mail and then delete this message from your system. Please do not copy it or use it for any purposes, or disclose its contents to any other person: to do so could be a breach of confidence. Thank you for your co-operation. Please contact our IT Helpdesk on +3902380481 or email [email protected] if you need assistance >>
Re: MEDEM sexagesimal number format Luca Cavalli
Prev: RE: Suppress modbus output Wallace, Alex
Next: sscan question lynn
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Next: Re: MEDEM sexagesimal number format Luca Cavalli
ANJ, 29 Nov 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
