1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Suppress modbus output
To: "'Wallace, Alex'" <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 28 Nov 2016 20:36:44 +0000
Hi Alex,
You can do the following to turn off messages:
asynSetTraceMask(“port”,-1,0)
where “port” is the name of the asyn port, -1 means all addresses, and 0 means all asyn trace mask bits are cleared (ASYN_TRACE_ERROR, ASYN_TRACE_FLOW, etc.).
What versions of asyn and modbus are you running?  In asyn R4-27 I changed the standard EPICS device support (asyn/devEpics) so that there should only be a single error message per record when a port disconnects and another single error message per record when a port reconnects.
However, I just looked at the Modbus driver, and it prints an error message when it gets an I/O error from the underlying TCP or serial driver.  It should not do that, it should just pass the error string up to device support.
Can you send me the error messages you are getting and I will fix the Modbus driver so that it does not print error messages when the device is disconnected.
From: [email protected] [mailto:[email protected]] On Behalf Of Wallace, Alex
Sent: Monday, November 28, 2016 1:33 PM
To: [email protected]
Subject: Suppress modbus output
Is there a flag or option for the Modbus connection functions to suppress the output when the connection is lost? My IOC logs are filling up!
-Alex
Suppress modbus output Wallace, Alex
Prev: Suppress modbus output Wallace, Alex
Next: RE: Suppress modbus output Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
ANJ, 28 Nov 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
