1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EPICS/RTEMS Compilation errors
To: Andrew Johnson <[email protected]>, [email protected]
Date: Mon, 28 Nov 2016 13:49:10 -0500
Hi Andrew,
Thanks
On 11/28/2016 12:32 PM, Andrew Johnson wrote:
On 11/28/2016 08:49 AM, Jianxun Yan wrote:
RTEMS version 4.11.
EPICS base3-15.1
I believe the libCom OS-interface layer in all released versions of
EPICS Base is only compatible with the API for RTEMS 4.10 and doesn't
have code in it for ARM CPUs either.
That's what I was thinking about.
Heinz Junkes is working on a port of Base for RTEMS 4.12 (actually for
RTEMS 4.11.99 which is the development branch for 4.12), but the core
developers haven't discussed his changes much yet and they aren't ready
to merge at this point. That discussion should be taking place at
https://code.launchpad.net/~junkes/epics-base/adap-rtems4.12/+merge/311305
If you're interested in helping with this porting effort we would happy
to have the additional help. Detailed discussions that are not directly
related to Heinz's code should take place on the core-talk mailing list.
Yes, I am interested in helping with this porting effort.
- Andrew
Jay
EPICS/RTEMS Compilation errors Jianxun Yan
Re: EPICS/RTEMS Compilation errors Andrew Johnson
Prev: Re: EPICS/RTEMS Compilation errors Jianxun Yan
Next: Suppress modbus output Wallace, Alex
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: EPICS/RTEMS Compilation errors Andrew Johnson
Next: Asyn daemon + console + log Benoit RAT
ANJ, 28 Nov 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
