1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EPICS Archiver appliance, only the first container is launched correctly
To: [email protected]
Date: Thu, 24 Nov 2016 12:52:32 +0100
In addition, please use 17668 also in the date_retrieval_url
in the form that http://localhost:17668/retrieval
Han
On 11/24/2016 12:50 PM, Jeong Han Lee wrote:
I looked at my appliances.xml, and found the difference
  between <cluster_inetport>localhost:17670</cluster_inetport>
  and  <cluster_inetport>localhost:16670</cluster_inetport>.
You might try to change the cluster_inetport.
  Han
On 11/24/2016 08:06 AM, Max Power wrote:
Dear guys, installing and checking the EPICS archiver appliance I have
the following problem.
The mgmt container (the first that I launch) is launched correctly, and
it permits me to add PVs and are registered correctly both in the
webbrowser as in the mySQL data base, but the following containers does
not execute because all of them report in the log file the same error:
Caused by: com.hazelcast.core.HazelcastException: Port [17670] is
already in use and auto-increment is disabled. Hazelcast cannot start
I understand waht it means, but I follow the configuration explained in
the https://slacmshankar.github.io/epicsarchiver_docs/installguide.html
my appliance configuration is:
<appliances>
   <appliance>
     <identity>appliance0</identity>
     <mgmt_url>http://localhost:17665/mgmt/bpl</mgmt_url>
     <engine_url>http://localhost:17666/engine/bpl</engine_url>
     <etl_url>http://localhost:17667/etl/bpl</etl_url>
     <retrieval_url>http://localhost:17668/retrieval/bpl</retrieval_url>
     <data_retrieval_url>http://localhost/retrieval</data_retrieval_url>
   </appliance>
 </appliances>
the way in which I launch the cluster is:
function startTomcatAtLocation() {
    if [ -z "$1" ]; then echo "startTomcatAtLocation called without any
arguments"; exit 1; fi
    export CATALINA_HOME=$TOMCAT_HOME
    export CATALINA_BASE=$1
    echo "Starting tomcat at location ${CATALINA_BASE}"
    ARCH=`uname -m`
    if [[ $ARCH == 'x86_64' || $ARCH == 'amd64' ]]
    then
      echo "Using 64 bit versions of libraries"
###      export
LD_LIBRARY_PATH=${CATALINA_BASE}/webapps/engine/WEB-INF/lib/native/linux-x86_64:${LD_LIBRARY_PATH}
export
LD_LIBRARY_PATH=${CATALINA_BASE}/webapps/engine/WEB-INF/lib/native/linux-x86_64:/home/max/EPICS/base/lib/linux-x86_64:${LD_LIBRARY_PATH}
    else
      echo "Using 32 bit versions of libraries"
      export
LD_LIBRARY_PATH=${CATALINA_BASE}/webapps/engine/WEB-INF/lib/native/linux-x86:${LD_LIBRARY_PATH}
    fi
    pushd ${CATALINA_BASE}/logs
    ${CATALINA_HOME}/bin/jsvc \
        -server \
        -cp
${CATALINA_HOME}/bin/bootstrap.jar:${CATALINA_HOME}/bin/tomcat-juli.jar:/home/max/scratch/mgmt/webapps/WEB-INF/lib/log4j-1.2.17.jar
        ${JAVA_OPTS} \
        -Dcatalina.base=${CATALINA_BASE} \
        -Dcatalina.home=${CATALINA_HOME} \
        -cwd ${CATALINA_BASE}/logs \
        -outfile ${CATALINA_BASE}/logs/catalina.out \
        -errfile ${CATALINA_BASE}/logs/catalina.err \
        -pidfile ${CATALINA_BASE}/pid \
        org.apache.catalina.startup.Bootstrap run
     popd
function start() {
startTomcatAtLocation ${ARCHAPPL_DEPLOY_DIR}/mgmt
sleep 20s
startTomcatAtLocation ${ARCHAPPL_DEPLOY_DIR}/engine
sleep 20s
startTomcatAtLocation ${ARCHAPPL_DEPLOY_DIR}/etl
sleep 20s
startTomcatAtLocation ${ARCHAPPL_DEPLOY_DIR}/retrieval
any idea?
Thank you in advance
EPICS Archiver appliance, only the first container is launched correctly Max Power
Re: EPICS Archiver appliance, only the first container is launched correctly Jeong Han Lee
Prev: Re: EPICS Archiver appliance, only the first container is launched correctly Jeong Han Lee
Next: Re: EPICS Archiver appliance, only the first container is launched correctly Shankar, Murali
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Next: EPICS on RTEMS: nfsmount problem "भावना नितिन मेढ़"
ANJ, 24 Nov 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
