Hi
I am trying to get "limits" to work on a "Soft Channel" record.
The challenge is that I
have the limit values in another record, and want to make a link
between the two records.
I would therefore like to something like this:
record(ao, "$(P):SUBCRYO_SETP_S") {
field(DESC, "Huginn Sub-cryostat system setpoint")
field(DTYP, "Soft Channel")
field(VAL, "300")
field(PREC, "3")
field(EGU, "K")
field(PINI, "YES")
field(HSV, "MINOR")
field(LSV, "MINOR")
field(LOW, "$(P):SUBCRYO_SETP_MIN.VAL CP")
field(HIGH, "$(P):SUBCRYO_SETP_MAX CP")
which, however, does not work.
It this possible, and in that case how.
Thanks in advance.
Bo
- EPICS Base Release-Candidate Double Feature! Andrew Johnson
- RE: EPICS Base Release-Candidate Double Feature! freddie.akeroyd
- Re: EPICS Base Release-Candidate Double Feature! Andrew Johnson
- Re: EPICS Base Release-Candidate Double Feature! Johnson, Andrew N.
- Re: EPICS Base Release-Candidate Double Feature! Matt Rippa
RE: Linking a HIGH and LOW field to a PV Steiner, Mathias
<2016>
<2016>
ANJ, 21 Nov 2016 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
