On Fri, 2016-11-18 at 11:55 +0100, Giovanna Campogiani wrote:
> Dear colleagues,
> many thanks for the useful and fast input on my issue.
> I realise now I forgot to paste the final line in the MCA error
> message: the full error message being
> cc1plus: error: unrecognized command line option "-std=c++11"
Looks like your 4.4.6 C++ compiler might be too old to support the
-std=c++11 switch. Try to use -std=c++0x as suggested here http://stack
overflow.com/questions/16456630/std-c11-flag-unrecognized-in-g-4-4-6.
Hinko
> make: *** [O.linux-x86_64/mca.mexa64] Error 255
> I modified the Makefile to look for a mca.mexa64 instead of
> mca.mexglx file as that would be the correct extension for the file.
> In attachment I put the stdout and stderr messages
> I'll have a look at the PSI protocol, it's very interesting, would it
> be suitable for operation with Matlab Middle Layer as well?
> Cheers,
> Giovanna
> 2016-11-18 10:52 GMT+01:00 Ebner Simon Gregor (PSI) <simon.ebner@psi.
> ch>:
> > Hi Giovanna
> > This is not directly related to your question, however it might
> > solve your base issue to have Channel Access in Matlab.
> > At PSI we use and (only) support this Channel Access package for
> > Matlab: https://github.com/channelaccess/ca_matlab
> > No compilation no installation … you only need a recent Matlab.
> > Best
> > Simon
> > > On 18 Nov 2016, at 09:48, Giovanna Campogiani <giovanna.campogian
> > [email protected]> wrote:
> > > Dear colleagues,
> > > I am trying to make the configuration files for MCA or LabCA on a
> > Scientific Linux 64bit machine and I am get the errors at the
> > bottom of the email.
> > > While searching for an answer I learnt probably the problem is
> > within the fact that both MCA and LabCA are for a 32 bit pc. How to
> > make MCA and LabCA compatible for a 64 bit version of MATLAB?
> > > Is this the real issue or am I missing something else?
> > > Many thanks for your support,
> > > best regards,
> > > Giovanna
> > > Errors reports
> > > when trying to make MCA
> > > /local/MATLAB/R2016b/bin/mex" -v -I/opt/codac-
> > 4.1/epics/base/include -I/opt/codac-4.1/epics/base/include/os/Linux
> > -DEPICS_DLL_NO -L/opt/codac-4.1/epics/base/lib/linux-x86_64
> > -ldbStaticHost -lCom -lca mca.cpp MCAError.cpp Channel.cpp -O
> > O.linux-x86_64/mca.mexglx
> > > Verbose mode is on.
> > > when trying to make LabCA
> > > make -C ./configure install
> > > make[1]: Entering directory `/home/codac-
> > dev/MATLAB/labca_3_5_0/configure'
> > > make -C O.linux-x86_64 -f ../Makefile TOP=../.. T_A=linux-x86_64
> > install
> > > make[2]: Entering directory `/home/codac-
> > dev/MATLAB/labca_3_5_0/configure/O.linux-x86_64'
> > > perl /opt/codac-4.1/epics/base/bin/linux-x86_64/convertRelease.pl
> > checkRelease
> > > make[2]: Leaving directory `/home/codac-
> > > make[1]: Leaving directory `/home/codac-
> > > make -C ./ezca install
> > dev/MATLAB/labca_3_5_0/ezca'
> > install
> > dev/MATLAB/labca_3_5_0/ezca/O.linux-x86_64'
> > > /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
> > -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE
> > -Dlinux -D_REENTRANT -O3 -g -Wall -g -m64 -fPIC -MMD
> > -I. -I../O.Common -I. -I.. -I../../include/os/Linux
> > -I../../include ../ezca.c
> > > Giovanna Campogiani
> > > Accelerator Physics PhD Student
> > > Electronics Engineer
> > > Sapienza University of Rome
> > > INFN - National Institute of Nuclear Physics
> > > e-mail: [email protected]
- RE: MCA or LabCA on Linux-64bit Allison, Stephanie
- MCA or LabCA on Linux-64bit Giovanna Campogiani
- Re: MCA or LabCA on Linux-64bit Ebner Simon Gregor (PSI)
- Re: MCA or LabCA on Linux-64bit Giovanna Campogiani
Re: Modbus Device Support for Advantech ADAM6017, 6018 Jeremy Wykes
Re: MCA or LabCA on Linux-64bit Till Straumann
<2016>
<2016>
