1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: OS X edm/medm openmotif woes
To: "J. Lewis Muir" <[email protected]>, Matt Newville <[email protected]>
Cc: Eric Norum <[email protected]>, tech-talk <[email protected]>
Date: Wed, 16 Nov 2016 04:12:14 +0000
There are translators from adl to the other 3 formats.  There is no other format with translators to all other 3.
Thus, for areaDetector I plan to stick to adl as the "standard", so we can autogenerate the other 3.
In areaDetector the opi, edl, and ui files are 2 directories, e.g. op/ui and op/ui/autoconvert.  The autoconverted files get put in op/ui/autoconvert, and should be updated each time the adl files change.  The op/ui directory is for files that were manually edited.
It would be nice if one could script the autoconversion process.  adl2ui and adl2edl are command line programs, so they can be scripted.  However, the conversion to CSS opi files can currently only be done in the CSS BOY GUI.  Since the conversion is really just a Java function it would be nice if someone were to package it so it can be called from the command line.
From: [email protected] [[email protected]] on behalf of J. Lewis Muir [[email protected]]
Sent: Tuesday, November 15, 2016 10:01 PM
To: Matt Newville
Cc: Eric Norum; tech-talk
Subject: Re: OS X edm/medm openmotif woes
On 11/15, Matt Newville wrote:
> Hi Lewis,
> I highly recommend caQtDM.  It works great on Mac OS X.  Automated
> translations of MEDM files with adl2ui works with very few (sometimes
> controls that have been grouped together in MEDM need to be un-grouped for
> accurate translation). Once translated, modifying or building new displays
> with QtDesigner is very easy, and allows features that MEDM will never
> support.
Hi, Matt!
Thanks for the recommendation!  caQtDM looks quite interesting.
A concern for me is that I often want to include a GUI with EPICS-based
software I write.  To date, I've always included MEDM screens (i.e.,
.adl files).  I've noticed, however, that some modules include more than
one type of GUI.  For example, areaDetectors's ADCore has .adl, .edl,
and .opi files.  caQtDm's native GUI file format seems to be .ui files.
That makes four different GUI formats.  I'd hate to have to maintain
more than one GUI.
So, how do I provide a useful GUI and at the same time avoid maintaining
more than one?  You mention that adl2ui works well, but it sounds like
you would plan to convert MEDM screens once to .ui files, and then
continue in .ui files from there.  Is there a way to automatically
generate .adl, .edl, and .opi files from .ui files?  Or is there a
consensus forming around .ui files such that it would be reasonable to
just provide .ui files where I previously provided .adl files?
Thanks!
Lewis
Re: OS X edm/medm openmotif woes Ralph Lange
OS X edm/medm openmotif woes Eric Norum
Re: OS X edm/medm openmotif woes Jiro Fujita
Re: OS X edm/medm openmotif woes Eric Norum
Re: OS X edm/medm openmotif woes J. Lewis Muir
Re: OS X edm/medm openmotif woes Matt Newville
Prev: Re: OS X edm/medm openmotif woes J. Lewis Muir
Next: Re: OS X edm/medm openmotif woes Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
ANJ, 16 Nov 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
