1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Asyn readFloat64 not setting record value
To: "'David Green'" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 11 Nov 2016 16:10:47 +0000
Did you call callParamCallbacks()?  That is what triggers the callbacks to your record.  You also must set the record SCAN field to I/O Intr.
From: [email protected] [mailto:[email protected]] On Behalf Of David Green
Sent: Friday, November 11, 2016 7:56 AM
To: [email protected]
Subject: Asyn readFloat64 not setting record value
I've recently developed an application that inherits from asynPortDriver and overloads the appropriate methods. I'm able to send data from the application by writing the value variable in writeFloat64 to my txParameterList variable and sending the raw byes through the connection made in the OctetSyncIO object.
The problem is doing the reverse. Setting pValue to the appropriate rxParameterList value does not update my record. What could I be missing?
Thank you,
David Green
Asyn readFloat64 not setting record value David Green
Prev: Asyn readFloat64 not setting record value David Green
Next: Re: StreamDevice/AsynIPPort question Michael Westfall
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Next: FLOOR function in EPICS CALC error rory.clarke
ANJ, 11 Nov 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
