Mark,
I love you!
Never used asynDriver, but I'm reading the documentation right now from
http://www.aps.anl.gov/epics/modules/soft/asyn/R4-30/asynDriver.html
I will come back to the ML in case of problems.
Luca
On gio, 2016-11-10 at 14:56 +0000, Mark Rivers wrote:
> Hi Luca,
> Here is a database idiom that can be used for that:
> For write you write to the FileNumber PV. It does the actual I/O through
> FileNumber_write.
> When LabView updates the value FileNumber_RBV is changed. That will update
> FileNumber without processing FileNumber_write again.
> record(longout, "$(P)$(R)FileNumber")
> field(PINI, "YES")
> field(OUT, "$(P)$(R)FileNumber_write PP")
> field(VAL, "1")
> record(longout, "$(P)$(R)FileNumber_write")
> field(SDIS, "$(P)$(R)FileNumber_Sync.PACT")
> field(DISV, "1")
> field(DTYP, "asynInt32")
> field(OUT, "@asyn($(PORT),$(ADDR),$(TIMEOUT))FILE_NUMBER")
> record(longin, "$(P)$(R)FileNumber_RBV")
> field(INP, "@asyn($(PORT),$(ADDR),$(TIMEOUT))FILE_NUMBER")
> field(SCAN, "I/O Intr")
> field(FLNK, "$(P)$(R)FileNumber_Sync")
> record(longout, "$(P)$(R)FileNumber_Sync")
> field(DOL, "$(P)$(R)FileNumber_RBV NPP")
> field(OMSL, "closed_loop")
> field(OUT, "$(P)$(R)FileNumber PP")
> Mark
> From: [email protected] [[email protected]] on behalf
> of Luca Cavalli [[email protected]]
> Sent: Thursday, November 10, 2016 8:38 AM
> To: [email protected]
> Subject: Native NI LabVIEW/EPICS integration
> Dear all,
> I have to control a NI PXI device.
> The software is written in LabVIEW using native NI LabVIEW/EPICS
> interface,unfortunately it seems to only support a subset of PV properties (no
> EGU, limits etc.).
> My idea is to write a tiny IOC that maps the "raw" LabView variable (e.g.
> PV_NAME_RAW) to a complete EPICS PV (e.g. PV_NAME) with precision, EGU, alarms
> and limits.
> [My IOC] <--PV_NAME--> [LV Mapper IOC] <--PV_NAME_RAW--> [NI PXI]
> The problem is that my PV must be both readable and writable at the same time.
> I.e. when I write the PV_NAME variable I want also the PV_NAME_RAW variable to
> be updated, and when LabVIEW modifies PV_NAME_RAW value I want PV_NAME to
> reflect the change.
> How can I define my db in LV Mapper IOC? I'm a bit lost, shall I use an input
> record or output record?
> So far I only achieved single direction control (either input or output, not
> both at the same time).
> Thanks for your help.
> Luca
> << Le informazioni contenute in questo messaggio di posta elettronica e
> relativi allegati sono riservate e confidenziali e ne è vietata la diffusione
> in qualunque modo eseguita. Qualora Lei non fosse la persona a cui il presente
> messaggio è destinato, La invitiamo ad eliminarlo e a darcene gentile
> comunicazione. Quanto precede ai fini del rispetto delle Legge 675/96 e del
> Decreto Legislativo 30/06/2003 n.196, sulla tutela dei dati personali >>
> << This e-mail is confidential and may well also be legally privileged. If you
> have received it in error, you are on notice of its status. Please notify us
> immediately by reply e-mail and then delete this message from your system.
> Please do not copy it or use it for any purposes, or disclose its contents to
> any other person: to do so could be a breach of confidence. Thank you for your
> co-operation. Please contact our IT Helpdesk on +3902380481 or email it@cgspac
> e.it if you need assistance >>
<< Le informazioni contenute in questo messaggio di posta elettronica e relativi allegati sono riservate e confidenziali e ne è vietata la diffusione in qualunque modo eseguita. Qualora Lei non fosse la persona a cui il presente messaggio è destinato, La invitiamo ad eliminarlo e a darcene gentile comunicazione. Quanto precede ai fini del rispetto delle Legge 675/96 e del Decreto Legislativo 30/06/2003 n.196, sulla tutela dei dati personali >>
<< This e-mail is confidential and may well also be legally privileged. If you have received it in error, you are on notice of its status. Please notify us immediately by reply e-mail and then delete this message from your system. Please do not copy it or use it for any purposes, or disclose its contents to any other person: to do so could be a breach of confidence. Thank you for your co-operation. Please contact our IT Helpdesk on +3902380481 or email [email protected] if you need assistance >>
- RE: Native NI LabVIEW/EPICS integration Mark Rivers
- Native NI LabVIEW/EPICS integration Luca Cavalli
Re: Opinion on timing system for synchrotron beamlines Márcio Paduan Donadio
deadlock in pcas 3.14.12.6-rc1 Wang Xiaoqiang (PSI)
<2016>
<2016>
