1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Opinion on timing system for synchrotron beamlines
To: Alessandro Drago <[email protected]>, Mark Rivers <[email protected]>
Cc: 'Márcio Paduan Donadio' <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 10 Nov 2016 13:32:53 +0000
Some other useful accelerator events of interest could be things like
informing of an upcoming (top-up) injection.
These are usually less precisely timed than revolution clock (or a
subharmonic of it) but can be comfortably propagated over a timing (event)
system.
I have not seen a big interest from beam lines to use highly precise and
synchronised timestamps so far, although I can easily imagine cases where
that might be interesting. But I am not a beam line scientist so this is
just my imagination.
Most timing in the experiments happens anyway in a level where EPICS
cannot contribute much, so probably PTP level of accuracy is sufficient.
Timo
On 10/11/16 09:43, "[email protected] on behalf of Alessandro
Drago" <[email protected] on behalf of
[email protected]> wrote:
>The same situation at DAFNE, we use fiducial (revolution ring clock) and
>injection trigger,
>Alessandro
>Il 2016-11-10 01:26 Mark Rivers ha scritto:
>> At the APS I would say that as far as I know no beamlines rely on
>> accurate timestamps from the accelerator timing system.   The
>> timestamps that the beamlines are using are based on NTP timing, so
>> are probably good to a few ms?
>> What the beamlines do use are hardware timing signals that allow
>> experiments to synchronize to the ring electron bunch structure.
>> There is one signal that is a pulse at the ring frequency (orbital
>> period) and another that gives a pulse for each bunch in the ring.
>> These are used to synchronize lasers, fast shutters, fast detectors,
>> etc.
>> Mark
>> -----Original Message-----
>> From: [email protected]
>> [mailto:[email protected]] On Behalf Of Márcio Paduan
>> Donadio
>> Sent: Wednesday, November 09, 2016 1:27 PM
>> To: [email protected]
>> Cc: Márcio Paduan Donadio
>> Subject: Opinion on timing system for synchrotron beamlines
>>      I'd like to know your experience regarding integration of the
>> accelerator timing system with the beamlines:
>>      - Which accelerator events are useful for the beamlines' control
>> system.
>>      - Do the beamlines use a global and very precise timestamp sent
>> from the accelerator timing system? What is the time precision?
>>      - Do you think that a PTP system is sufficient for timestamping
>> experiments in beamlines?
>>      - What is the EPICS role regarding such a timing system?
>>      Thank you,
Re: Opinion on timing system for synchrotron beamlines bob dalesio
Opinion on timing system for synchrotron beamlines Márcio Paduan Donadio
RE: Opinion on timing system for synchrotron beamlines Mark Rivers
RE: Opinion on timing system for synchrotron beamlines Alessandro Drago
Prev: RE: Opinion on timing system for synchrotron beamlines Alessandro Drago
Next: Re: Opinion on timing system for synchrotron beamlines bob dalesio
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
ANJ, 10 Nov 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
