1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EPICS Base Release-Candidate Double Feature!
To: Ben Franksen <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Wed, 9 Nov 2016 09:13:18 +0100
Hello Ben,
you are right. I asked if I should create a new OS_CLASS (preferred by me as there where some changes needed even to the posix-part).
It was also a first try to use the posix stuff with RTEMS and get rid of RTEMS-internal (_XXX) functions.
I have choosen the way with the #ifdef’s to not break the existing RTEMS-Port.
I found no way to realise it with the build system. I am open for any “good idea”.
Heinz
> On 09 Nov 2016, at 02:01, Ben Franksen <[email protected]> wrote:
> Hello Heinz & EPICS Gurus
> I have just taken a quick look at your port. I may be wrong but it looks
> to me as if you have copied lots of osi implementation code from
> osd/posix to existing files in osd/RTEMS (surrounded with #ifdefs).
> There must be a better way to do this! If you have confirmed that there
> isn't, then you should report this as a bug and/or feature request
> against EPICS base. It should be possible to persuade the build system
> to ignore (some of the) existing osd/RTEMS files, making it fall back to
> using the ones from osd/posix. If all else fails, perhaps it makes more
> sense to create a new OS_CLASS (e.g. RTEMS412)?
> Cheers
> Ben
> Am 07.11.2016 um 08:52 schrieb Heinz Junkes:
>> Hi Matt,
>> I made a port of EPICS 3.15 for RTEMS 4.12 (tested on MVME6100, beatnik)
>> And put it for review to the launchpad:
>> https://code.launchpad.net/~junkes/epics-base/adap-rtems4.12
>> There is also a pull request for bundleCPP (epics v4):
>> https://github.com/hjunkes/bundleCPP
>> Cheers,
>> Heinz
>>> On 06 Nov 2016, at 23:38, Matt Rippa <[email protected]> wrote:
>>> Is it expected that either of the latest 3.14 or 3.15 releases should build against RTEMS 4.11 ?
>>> Trying with 3.15.5-rc1 and RTEMS 4.11 I get the following error below. I'm using the beatnik, mvme2307 and mvme3100 bsp's.
>>> FWIW, 3.15.5-rc1 builds fine against RTEMS 4.10.
>>> -Matt
>>> <snip>
>>> make[3]: Leaving directory `/home/mrippa/work/vendor/epics/base-3.15.5-rc1/src/libCom/O.RTEMS-beatnik'
>>> make[3]: Entering directory `/home/mrippa/work/vendor/epics/base-3.15.5-rc1/src/libCom/O.RTEMS-beatnik'
>>> Installing generic include file /gem_sw/epics/R3.15.5-rc1/base/include/os/RTEMS/osiFileName.h
>>> mkdir /gem_sw/epics/R3.15.5-rc1/base/include/os/RTEMS
>>> Installing generic include file /gem_sw/epics/R3.15.5-rc1/base/include/os/RTEMS/osdSock.h
>>> <snip>
>>> /gem_sw/targetOS/RTEMS/rtems-4.11/bin/powerpc-rtems4.11-gcc --pipe -B/gem_sw/targetOS/RTEMS/rtems-4.11/powerpc-rtems4.11/beatnik/lib/ -specs bsp_specs -qrtems   -fa
>>> sm   -mcpu=7400 -D__ppc_generic                     -DUNIX      -O2 -g   -Wall       -DMY_DO_BOOTP=NULL -DHAVE_MOTLOAD -DRTEMS_NETWORK_CONFIG_MBUF_SPACE=2048 -DRTEM
>>> S_NETWORK_CONFIG_CLUSTER_SPACE=5120     -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/l
>>> ibCom/osi/os/RTEMS -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../
>>> src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLi
>>> b -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/
>>> gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom
>>> /pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCo
>>> m/yajl -I/gem_sw/epics/R3.15.5-rc1/base/include/compiler/gcc -I/gem_sw/epics/R3.15.5-rc1/base/include/os/RTEMS -I/gem_sw/epics/R3.15.5-rc1/base/include         -c .
>>> ./../../src/libCom/osi/os/RTEMS/osdPoolStatus.c
>>> ../../../src/libCom/osi/os/RTEMS/osdPoolStatus.c: In function 'osiSufficentSpaceInPool':
>>> ../../../src/libCom/osi/os/RTEMS/osdPoolStatus.c:20:5: error: unknown type name 'rtems_malloc_statistics_t'
>>>    rtems_malloc_statistics_t s;
>>> ../../../src/libCom/osi/os/RTEMS/osdPoolStatus.c:23:5: warning: implicit declaration of function 'malloc_get_statistics' [-Wimplicit-function-declaration]
>>>    malloc_get_statistics(&s);
>>> ../../../src/libCom/osi/os/RTEMS/osdPoolStatus.c:24:10: error: request for member 'space_available' in something not a structure or union
>>>    n = s.space_available - (unsigned long)(s.lifetime_allocated - s.lifetime_freed);
>>> ../../../src/libCom/osi/os/RTEMS/osdPoolStatus.c:24:46: error: request for member 'lifetime_allocated' in something not a structure or union
>>> ../../../src/libCom/osi/os/RTEMS/osdPoolStatus.c:24:69: error: request for member 'lifetime_freed' in something not a structure or union
>>> make[3]: *** [osdPoolStatus.o] Error 1
>>> make[2]: *** [install.RTEMS-beatnik] Error 2
>>> make[2]: Leaving directory `/home/mrippa/work/vendor/epics/base-3.15.5-rc1/src/libCom'
>>> make[1]: *** [libCom.install] Error 2
>>> make[1]: Leaving directory `/home/mrippa/work/vendor/epics/base-3.15.5-rc1/src'
>>> make: *** [src.install] Error 2
>>> On Mon, Oct 31, 2016 at 1:05 PM, Andrew Johnson <[email protected]> wrote:
>>> Ralph Lange and I have today tagged and generated Release Candidate[1]
>>> versions of two new versions of EPICS Base for testing purposes. The
>>> final releases of these will happen in about 2 weeks time provided no
>>> major problems are reported in that period. Please report any problems
>>> you find with these to this tech-talk mailing list.
>>> Base-3.14.12.6-rc1
>>>  See http://www.aps.anl.gov/epics/base/R3-14/12.php for the download
>>> link and Release Notes.
>>> Base-3.15.5-rc1
>>>  See http://www.aps.anl.gov/epics/base/R3-15/5.php for the download
>>> link and documentation.
>>> These releases contain bug-fixes and various minor updates, and should
>>> be compatible with software written for previous releases. See the
>>> published Release Notes for details. Most of these modifications were
>>> first applied to the Base-3.14 branch and the changes merged up to the
>>> Base-3.15 branch.
>>> One new feature that is present in both releases is that PCAS now
>>> supports variable length array monitor updates — thanks to Matej
>>> Sekoranja, Bruce Hill and Ralph Lange for implementing that.
>>> The 3.15 branch does contain a major performance improvement to the IOC
>>> when loading large numbers of database records.
>>> Thanks to all the EPICS Core Developers for their work on these releases.
>>> - Andrew Johnson
>>> [1] Today's scary word for US residents
>>> Arguing for surveillance because you have nothing to hide is no
>>> different than making the claim, "I don't care about freedom of
>>> speech because I have nothing to say." -- Edward Snowdon
Attachment: smime.p7s
Description: S/MIME cryptographic signature
EPICS Base Release-Candidate Double Feature! Andrew Johnson
Re: EPICS Base Release-Candidate Double Feature! Matt Rippa
Re: EPICS Base Release-Candidate Double Feature! Heinz Junkes
Re: EPICS Base Release-Candidate Double Feature! Ben Franksen
Prev: Re: processCallbacks() never called in areaDetector plugin Ben Franksen
Next: Control System Engineer vacancies at Diamond ulrik.pedersen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: EPICS Base Release-Candidate Double Feature! Ben Franksen
Next: RE: EPICS Base Release-Candidate Double Feature! freddie.akeroyd
ANJ, 10 Nov 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
