1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: processCallbacks() never called in areaDetector plugin
To: <[email protected]>
Date: Wed, 9 Nov 2016 02:41:39 +0100
Am 08.11.2016 um 14:08 schrieb Mark Rivers:
> Actually I think you need to call start() in the code that created
> the object, not in the constructor.  The problem is that the derived
> class needs to be completely constructed before start() is called.
Am 08.11.2016 um 18:14 schrieb Mark Rivers:
>> What was causing the problem with this being handled in the base
>> class  as before?
> The start() method was added in R2-5.  The problem was race
> conditions that were discovered when running the unit tests in the
> pluginTest directory.  Those tests instantiate drivers and plugins
> that only exist for a very short amount of time.  As I recall the
> problems were one or more of the following:
> - The first callback occurred before the thread that processes the
> plugins had started running.  The callbacks can start as soon as the
> base class constructor is called.
> - The first callback occurred before the derived class constructor
> was complete.  In this case the base class processCallbacks method
> will be called, not the derived class method, which is not what is
> intended.
> - The destructor was called before the thread had a chance to process
> the callback.
> To fix these problems the start() method was added, and it must be
> called by the code that instantiates the plugin.
These problems are symptoms of a disease that goes deeper and is more
general. Indeed, subclassing is not (and cannot easily be made) aware of
complex initialization protocols. This is a fundamental shortcoming of
the OO paradigm and one of the reasons why APIs that require the user to
derive subclasses are difficult to use correctly. The functional
approach is much more flexible here: instead of letting users derive
subclasses, you require the user's init function to be passed as a
parameter to the "base class" init function. The latter remains in
control of the overall initialization order; the protocol is
encapsulated and extensions cannot break it. This gives you an API that
is much easier to use.
Cheers
Ben
Attachment: signature.asc
Description: OpenPGP digital signature
processCallbacks() never called in areaDetector plugin Jonas Nilsson
Re: processCallbacks() never called in areaDetector plugin Siniša Veseli
RE: processCallbacks() never called in areaDetector plugin Mark Rivers
Prev: Re: EPICS Base Release-Candidate Double Feature! Ben Franksen
Next: Re: EPICS Base Release-Candidate Double Feature! Heinz Junkes
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: processCallbacks() never called in areaDetector plugin Mark Rivers
Next: Multiple NDPluginPva issues Alexander Söderqvist
ANJ, 09 Nov 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
