1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EPICS Base Release-Candidate Double Feature!
To: Keith Thorne <[email protected]>, epics Techtalk <[email protected]>
Date: Thu, 3 Nov 2016 17:40:34 -0400
On 11/03/2016 05:23 PM, Keith Thorne wrote:
> Dear Andrew (and others)
> 	At LIGO, we appreciate the changes for faster loading of databases.
> Question: do any of these changes (and the use of dbPvdTableSize shown below) relevant to EPICS gateways?
> We have some very busy gateways (> 100,000 PVs) at present.
No. this change is specific to the process database, specifically the
.db file parser.
https://code.launchpad.net/~epics-core/epics-base/bigdb-3.15/+merge/307834
> 	Thanks
> 		Keith Thorne
>> On Nov 3, 2016, at 10:27 AM, Andrew Johnson <[email protected]> wrote:
>> Hi Murali,
>> On 11/02/2016 06:21 PM, Shankar, Murali wrote:
>>>>> The 3.15 branch does contain a major performance improvement to the IOC
>>>>> when loading large numbers of database records.
>>> Awesome, I can load 100K PV's into a softIOC in a couple of seconds!
>>> Thank you so much!
>> If you are loading large numbers of records also make sure that you are
>> setting the size of the IOC's hash-table before dbLoadDatabase() or
>> dbLoadRecords() in your startup script. The size argument must be a
>> power of 2 up to 64K:
>>    dbPvdTableSize(65536)
>> The default size is 512, although we should probably increase that
>> nowadays. More hash buckets means more efficient name searches both at
>> load-time and by the CA name resolution task.
>> - Andrew
>> Arguing for surveillance because you have nothing to hide is no
>> different than making the claim, "I don't care about freedom of
>> speech because I have nothing to say." -- Edward Snowdon
> CDS Software Engineer
> LIGO Livingston Laboratory
> Livingston, LA 70754
> Phone: (225)686-3168 Fax: (225)686-7189
Re: EPICS Base Release-Candidate Double Feature! Shankar, Murali
Re: EPICS Base Release-Candidate Double Feature! Andrew Johnson
Re: EPICS Base Release-Candidate Double Feature! Keith Thorne
Prev: Re: EPICS Base Release-Candidate Double Feature! Ralph Lange
Next: Re: EPICS Base Release-Candidate Double Feature! Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
ANJ, 03 Nov 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
