1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Error with RTEMS on MVME5500
To: [email protected]
Date: Mon, 31 Oct 2016 10:26:59 -0400
On 10/31/2016 07:41 AM, "भावना नितिन मेढ़" wrote:
> Is it possible that I do not use NFS at all? I have used
> -DOMIT_NFS_SUPPORT, but still NFS is being used.
This option has been broken for some time due (I think) to rtems api
changes.  I have most of a fix for this, but it's been stalled for lack
of my time (https://github.com/mdavidsaver/epics-base/commits/multiboot).
Also, the TFTP client is broken in all rtems 4.10.x releases
(https://devel.rtems.org/ticket/2375).  >=4.11 doesn't work with epics
yet (Heinz is working on this).
> What is the other method to load st.cmd. In VxWorks it was pretty simple,
> just provide the path of st.cmd.
Unless you are prepared to do, or sponsor, some work the only realistic
option for RTEMS is NFSv3.
Michael
> -Bhavna
>> Another quick check of an NFS server is 'showmount -e 100.100.100.110'
>> to probe the running server.  Failed mount attempts should be logged (eg
>> /var/log/syslog or similar).
>> Also, the RTEMS NFS client doesn't speak NFSv4 yet.
>> On 10/28/2016 12:05 PM, Heinz Junkes wrote:
>>> Bhavna,
>>> on host 100.100.100.110 there must be a nfs server running.
>>> Please check that host for nfs.server processes:
>>> $ ps -ef | grep nfsd
>>> rtems     5536  5516  0 18:01 pts/14   00:00:00 grep --color=auto nfsd
>>> root     19606     2  0 Aug30 ?        00:00:00 [nfsd4]
>>> root     19607     2  0 Aug30 ?        00:00:00 [nfsd4_callbacks]
>>> root     19611     2  0 Aug30 ?        00:00:00 [nfsd]
>>> root     19612     2  0 Aug30 ?        00:00:00 [nfsd]
>>> root     19613     2  0 Aug30 ?        00:00:00 [nfsd]
>>> root     19614     2  0 Aug30 ?        00:00:00 [nfsd]
>>> root     19615     2  0 Aug30 ?        00:00:00 [nfsd]
>>> root     19616     2  0 Aug30 ?        00:00:00 [nfsd]
>>> root     19617     2  0 Aug30 ?        00:00:00 [nfsd]
>>> root     19618     2  0 Aug30 ?        00:00:00 [nfsd]
>>> and /etc/exports
>>> that there is an entry for /tftpboot/rt_test3 like this:
>>> $ more /etc/exports
>>> # /etc/exports: the access control list for filesystems which may be
>>> exported
>>> #to NFS clients.  See exports(5).
>>> /tftpboot/rt_test3       100.100.100.0/24(rw,sync,no_subtree_check)
>>> HTH,
>>> Heinz
>>> Fritz-Haber-Institut    | Phone:         (+49 30) 8413-4270
>>> Heinz Junkes             | Fax (G3+G4):   (+49 30) 8413-5900
>>> Faradayweg 4-6        |
>>> D - 14195 Berlin        | E-Mail:     [email protected]
>>> <mailto:[email protected]>
>>> On 28 October 2016 at 11:22:43, भावना नितिन%
Re: Error with RTEMS on MVME5500 Michael Davidsaver
Re: Error with RTEMS on MVME5500 "भावना नितिन मेढ़"
Prev: Re: Error with RTEMS on MVME5500 "भावना नितिन मेढ़"
Next: Re: CA connection problems between VxWorks and Windows Michael Davidsaver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Next: Re: Error with RTEMS on MVME5500 Michael Davidsaver
ANJ, 31 Oct 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
