1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Error with RTEMS on MVME5500
To: epicsmail <[email protected]>, भावना नितिन मेढ़ <[email protected]>
Date: Fri, 28 Oct 2016 18:05:32 +0200
Bhavna,
on host 100.100.100.110 there must be a nfs server running.
Please check that host for nfs.server processes:
$ ps -ef | grep nfsd
rtems     5536  5516  0 18:01 pts/14   00:00:00 grep --color=auto nfsd
root     19606     2  0 Aug30 ?        00:00:00 [nfsd4]
root     19607     2  0 Aug30 ?        00:00:00 [nfsd4_callbacks]
root     19611     2  0 Aug30 ?        00:00:00 [nfsd]
root     19612     2  0 Aug30 ?        00:00:00 [nfsd]
root     19613     2  0 Aug30 ?        00:00:00 [nfsd]
root     19614     2  0 Aug30 ?        00:00:00 [nfsd]
root     19615     2  0 Aug30 ?        00:00:00 [nfsd]
root     19616     2  0 Aug30 ?        00:00:00 [nfsd]
root     19617     2  0 Aug30 ?        00:00:00 [nfsd]
root     19618     2  0 Aug30 ?        00:00:00 [nfsd]
and /etc/exports
that there is an entry for /tftpboot/rt_test3 like this:
$ more /etc/exports
# /etc/exports: the access control list for filesystems which may be exported
# to NFS clients.  See exports(5).
/tftpboot/rt_test3       100.100.100.0/24(rw,sync,no_subtree_check)
HTH,
Heinz
Fritz-Haber-Institut    | Phone:         (+49 30) 8413-4270
Heinz Junkes             | Fax (G3+G4):   (+49 30) 8413-5900
Faradayweg 4-6        |
D - 14195 Berlin        | E-Mail:     [email protected]
On 28 October 2016 at 11:22:43, भावना नितिन मेढ़ ([email protected]) wrote:
I am using EPICS base 3.14.12.4 built on Centos6.5 with RTEMS version 4.9.1
The command below works ok.
tftpget -c100.100.100.101 -s100.100.100.110 -g100.100.100.110
-d/dev/enet0-a04000000 -f/rt_test3/bin/RTEMS-mvme5500/test.boot
I am getting following error while trying to load EPICS IOC for RTEMS on
MVME5500.
MVME5500> go -a04000000
Welcome to rtems-4.9.2(PowerPC/Generic (classic FPU)/mvme5500) on
MVME5500-0163
Now BSP_mem_size = 0x1FE00000
rtems_configuration_get_work_space_size() = 1F4000
Universe II PCI-VME bridge detected at 0x82000000, IRQ 12
Universe Master Ports:
Port VME-Addr Size PCI-Adrs Mode:
0: 0x20000000 0x0E000000 0x90000000 A32, D64 [MBLT], Dat, Sup
1: 0x00000000 0x00FF0000 0x9F000000 A24, D64 [MBLT], Dat, Sup
2: 0x00000000 0x00010000 0x9FFF0000 A16, D64, Dat, Sup
Universe Slave Ports:
0: 0x90000000 0x1FE00000 0x00000000 A32, Pgm, Dat, Sup, Usr, PWEN, PREN
Overriding main IRQ line PCI info with 76
Registering /dev/console as minor 0 (==/dev/ttyS0)
***** Initializing network *****
Startup.
Ethernet driver name wmG unit 1
Copyright (c) 2004,2005 S. Kate Feng <[email protected]> (RTEMS/mvme5500 port)
***** Initializing NFS *****
RTEMS-RPCIOD $Release$, Till Straumann, Stanford/SLAC/SSRL 2002, See
LICENSE fi.
RTEMS-NFS $Release$, Till Straumann, Stanford/SLAC/SSRL 2002, See LICENSE
file .
Trying to mount 100.100.100.110:/tftpboot/rt_test3 on /tftpboot/rt_test3
RPCIO: server '100.100.100.110' not responding - still trying
Unable to contact NFS server - invalid port? (RPC: Timed out)
nfsMount - mount: Unknown protocol
rtems_bsdnet_get_ntp() Can't send: Host is down
***** Starting EPICS application *****
Can't set initial directory(/tftpboot/rt_test3/iocBoot/ioctest/): No such
file y
Can't set initial directory():
fatal error, exiting
Printing a stack trace for your convenience :-)
0x00128D84--> 0x00118204--> 0x001181D0--> 0x00003254
RTEMS terminated; Boot manually or turn on AUTO_BOOT.
I have set following variables.
MVME5500> gevshow
mot-/dev/enet1-cipa=192.168.1.99
mot-/dev/enet1-sipa=192.168.1.4
mot-/dev/enet1-gipa=192.168.1.1
mot-/dev/enet1-file=bootrom.bin
epics-script=/tftpboot/rt_test3/iocBoot/ioctest/st.cmd
mot-/dev/enet0-cipa=100.100.100.101
mot-/dev/enet0-sipa=100.100.100.110
mot-/dev/enet0-snma=255.255.255.0
mot-/dev/enet0-gipa=100.100.100.110
epics-nfsmount=100.100.100.110:/tftpboot/rt_test3:/tftpboot/rt_test3
Total Number of GE Variables =10, Bytes Utilized =395, Bytes Free =3197
Please suggest.
Bhavna
Attachment: smime.p7s
Description: S/MIME cryptographic signature
Re: Error with RTEMS on MVME5500 Michael Davidsaver
Error with RTEMS on MVME5500 "भावना नितिन मेढ़"
Prev: Error with RTEMS on MVME5500 "भावना नितिन मेढ़"
Next: Re: Error with RTEMS on MVME5500 Michael Davidsaver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
ANJ, 28 Oct 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
