1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EPICS with LabVIEW
To: palak shimpee <[email protected]>, <[email protected]>
Date: Mon, 24 Oct 2016 12:14:57 -0500
Presumably your set up is that you have 2 EPICS CA clients (Labview and CSS)
running on the same host machine connecting to a EPICS PV on the same subnet.
One connects (CSS) and the other does not (Labview).
If your EPICS PVs are really strings then Labview should probably not be using
a numeric indicator as shown in the screen shot.
Is this a CRio Labview system?
Also what is the Labview OS: vxWorks, Linux, Windows?
We have noticed here that without some modification the CRio system running
under vxWorks sends the CA request to broadcast address 255.255.255.255 by
default.
Marty
On 10/24/2016 03:19 AM, palak shimpee wrote:
I have two variables with data-type as string. The variables are
CWS-TXX-WFC:SpeedFB and CWS-TXX-WFC:SpeedSP. EPICS and LabVIEW are on same host.
In LabVIEW , I have made a project to read these variables from CSS and its
screenshots are attached. I have made these as shared variable and also done
EPICS settings in CSS. But I an unable to get the values in LabVIEW and is
showing an error.
EPICS with LabVIEW palak shimpee
Prev: Pending synApps pull requests Henrique Almeida
Next: mrfioc2 releases 2.0.5 and 2.1.0 Michael Davidsaver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: EPICS with LabVIEW Paul Sichta
Next: assert in caserverio.c Vodopivec, Klemen
ANJ, 24 Oct 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
