1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EPICS with LabVIEW
To: palak shimpee <[email protected]>
Date: Mon, 24 Oct 2016 10:06:06 -0400
Palak,
In my understanding CSS will not serve EPICS PV's since it is an EPICS client.  You should use the LabVIEW server method;  your screenshot shows you are using the LabVIEW client.  If you want I can send you some screen shots of our LabVIEW server configuration (we also are using the client method in another system).  In that, we populate the EPICS Server1 with PV's, and associate/bind each PV with a  LabVIEW network published variable.
-Paul Sichta
PPPL
On Mon, Oct 24, 2016 at 4:19 AM, palak shimpee <[email protected]> wrote:
I have two variables with data-type as string. The variables are CWS-TXX-WFC:SpeedFB and CWS-TXX-WFC:SpeedSP. EPICS and LabVIEW are on same host. In LabVIEW , I have made a project to read these variables from CSS and its screenshots are attached. I have made these as shared variable and also done EPICS settings in CSS. But I an unable to get the values in LabVIEW and is showing an error.
EPICS with LabVIEW palak shimpee
Prev: assert in caserverio.c Vodopivec, Klemen
Next: Re: assert in caserverio.c Michael Davidsaver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Prev: EPICS with LabVIEW palak shimpee
Next: Re: EPICS with LabVIEW Martin L. Smith
ANJ, 24 Oct 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
