1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: MEDM wheel switch Problem
To: PilkyuJung <[email protected]>, <[email protected]>
Date: Tue, 18 Oct 2016 11:27:20 -0500
Hi Jung,
On 10/18/2016 05:29 AM, PilkyuJung wrote:
> This is Jung who work at BMI. and I am using MEDM 3.1.8.1.
> I open New file. and when I make new Wheel Switch, I got error like this.
> Tue Oct 18 19:18:41 KST 2016
> xErrorHandler:
> BadDrawable (invalid Pixmap or Window parameter)
> This error is happened every controlling wheel switch. also it happened
> during use 3.1.9.
I can't answer your your question myself, but I know that anyone who
might be able to is going to want to know what platform (OS & version)
you are running MEDM on, and if you are using a remote X11 display what
OS is running the display server. These kinds of error are often due to
incompatibilities between our older code newer versions of the X-server
software.
- Andrew
MEDM wheel switch Problem PilkyuJung
Prev: MEDM wheel switch Problem PilkyuJung
Next: S7nodave/boost problem Remi FAURE
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
ANJ, 19 Oct 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
