1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Question about epics and pcaspy running in one computer
To: EPICS Tech Talk <[email protected]>
Date: Fri, 14 Oct 2016 19:28:34 +0200
Please also consider reading
which explains exactly that, including solutions that do not require any Channel Access client configuration.
Cheers,
~Ralph
On Fri, Oct 14, 2016 at 6:01 PM, Mark Rivers <[email protected]> wrote:
It should work fine to simply not define EPICS_CA_ADDR_LIST at all on either the client or server machine, as long as they are both on the same subnet.
From: [email protected] [[email protected]] on behalf of Kasemir, Kay [[email protected]]
Sent: Friday, October 14, 2016 10:24 AM
To: lzf neu
Cc: [email protected]
Hi:
> I defined the EPICS_CA_ADDR_LIST=127.0.0.1
That's your problem.
127.0.0.1 is not a broadcast address.
Read https://wiki-ext.aps.anl.gov/epics/index.php/How_to_Configure_Channel_Access, and find the broadcast address of the host which runs your IOCs.
Hint: It's an IP address that tends to end in 255.
-Kay
Question about epics and pcaspy running in one computer lzf neu
Re: Question about epics and pcaspy running in one computer Mark Rivers
答复: Question about epics and pcaspy running in one computer lzf neu
Re: Question about epics and pcaspy running in one computer Kasemir, Kay
RE: Question about epics and pcaspy running in one computer Mark Rivers
Prev: Re: EDM User Manual Andrew Johnson
Next: EPICS driver for XR-100SDD Biplab Ghosh
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Question about epics and pcaspy running in one computer Mark Rivers
Next: FW: archive engine Caizhen Liu
ANJ, 17 Oct 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
