Hi:
>We have about 4000 PVs being archived at the moment.
> It seems that the archiving have some issue starting from PV “OPS-EPICS:R:CCG1”.
> The queue is full and overruns happens. And there is no data record for PV OPS-EPICS:R:CCG1 in the postgres database.
> When I reduced the number of channels to be 90, everything seems ok.
More important than the number of PVs or the specific PV names is the number of samples that these channels produce.
The main web page of the archive engine will show you a "write count" and a "write duration".
From watching that for a while, you can compute the number of values that the engine can write to your relational database.
Bottom line is that the RDB approach for archiving is very reliable, but not fast.
You may simply reach some maximum supported number of samples/sec that you can write to your database.
When you build CSS from sources, you can execute the RDBArchiveWriterTest (https://github.com/ControlSystemStudio/cs-studio/blob/master/applications/archive/archive-plugins/org.csstudio.archive.writer.test/test/org/csstudio/archive/writer/rdb/RDBArchiveWriterTest.java).
Way back, I got these types of performance readings:
PostgreSQL: ~12000 samples/sec
MySQL: ~21000 samples/sec
Those are write speeds when the database is on the same computer that's also running the test, and nothing else is using the RDB.
In the real world, when you connect to a remote database that's also doing its day job, the numbers a lower.
The EPICS Archiver Appliance, https://slacmshankar.github.io/epicsarchiver_docs/index.html, is faster because it uses its own set of files instead of a relational database.
-Kay
- RE: archive engine Caizhen Liu
- FW: archive engine Caizhen Liu
答复: Question about epics and pcaspy running in one computer lzf neu
Re: Question about epics and pcaspy running in one computer Kasemir, Kay
<2016>
<2016>
