1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: CSS 4.33 / Mars 4.5.2 / BOY not found
To: Alex Squitieri <[email protected]>
Date: Wed, 12 Oct 2016 13:09:47 +0000
Hi:
> On Oct 10, 2016, at 12:01 PM, Alex Squitieri <[email protected]> wrote:
> Now trying to install a new CSS version on WIN7 box , and failing.  Steps so far:
> 	• Find CSS 4.3.3 on downloads page
> 	• Install Eclipse 4.5.2 Mars, point “use Software from” as directed to controlsystems etc URL, install everything from there . Many complaints about missing files.
> 	• Install CSS 4.3.3
You only need to install Eclipse if you intend to work on the source code.
To simply use the CSS UI, just download the zip with the executable.
> Both installations complain on startup about missing fonts , colors and \BOY examples\main.opi.
By default, it’s configured to use the example font and color config files from the BOY examples, and the “Top OPIs” also links to the main.opi from the BOY examples.
To install those, use the menu CS-Studio/Utilities/Install Samples.
> Alas, Help from css won’t launch.
The menu Help/Help Contents should start a web browser, which then shows the help served by a web server inside CS-Studio.
That can sometimes run into problems on Linux, because on Linux there’s no canonical way to start a web browser. Haven’t seen such an issue on the Mac or Windows, so that would be a new one.
You could check the menu Edit/Preferences, section General/Web Browser. “Default System Web Browser” should be checked. If that doesn’t “work”, you may have to add a new entry that points to a web browser on your computer. On Windows and Mac it usually auto-detects Firefox etc. so you can simply select them, but in any case you can create a new entry “MyBrowser” and point that to some web browser that you happen to have on your computer.
> I’ll be happy to uninstall everything and follow a known path to happiness if the versions are not the best, or happy to help debugging if new with logs etc.
I’m all for finding and then following a path to happiness.
For starters, finding the log file is easy. It’s the .metadata/.log file in the workspace, i.e. that folder which you select when you start CS-Studio.
You can view the content of that file via the menu Window/Show View/Other.. and then opening the General/Error Log, but opening that file in a plain text editor outside of CSS also works.
-Kay
CSS 4.33 / Mars 4.5.2 / BOY not found Alex Squitieri
Prev: EPICS driver for BERGOZ BCM Ford, Christopher
Next: Question about ASYN setting Input & Output EOS Michael Westfall
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Prev: CSS 4.33 / Mars 4.5.2 / BOY not found Alex Squitieri
Next: EPICS driver for BERGOZ BCM Ford, Christopher
ANJ, 12 Oct 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
