1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EPICS build system DESTDIR support
To: Andrew Johnson <[email protected]>, [email protected]
Date: Fri, 7 Oct 2016 14:53:38 -0400
On 10/05/2016 03:48 PM, Andrew Johnson wrote:
> If you or someone else wants to develop an alternative way to handle
> these build issues the core developers would be happy to advise and
> help, but any replacement must support builds on Linux, Windows and
> macOS/darwin at minimum, and handle cross-builds for the majority of our
> current cross-targets.
https://github.com/mdavidsaver/cmake4epics
cmake works great for hosted targets.  Cross compiling is rough, but
workable.  I have some helpers for dealing with EPICS stuff.  It
respects the usual cmake install scheme.
An example of building an IOC executable.
https://github.com/mdavidsaver/cmake4epics/blob/master/iocApp/CMakeLists.txt
A real support module and IOC
https://github.com/frib-high-level-controls/FLAME/blob/master/vaccel/CMakeLists.txt
EPICS build system DESTDIR support J. Lewis Muir
Re: EPICS build system DESTDIR support Andrew Johnson
Prev: RE: StreamDevice fails to compile for RTEMS targets. Mooney, Tim M.
Next: IOC Shell Function Registry Lang, Keenan C.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: EPICS build system DESTDIR support Andrew Johnson
Next: epics4 soft ioc Mezger Anton Christian (PSI)
ANJ, 07 Oct 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
