1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: ioc executable being made corrupted
To: "Crisp, Daniel" <[email protected]>, "Konrad, Martin" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 6 Oct 2016 08:04:21 +0200
Daniel,
if you track shell scripts in Git, I would warmly recommend to add a
.gitattributes file similar to this one:
https://github.com/epics-modules/motor/blob/master/.gitattributes
Note that the order of lines is important!
On 05/10/16 16:21, Crisp, Daniel wrote:
Thank you, very much. I suppose my mistake was thinking ^M was an indication of a file having a carriage return within it, not that ^M was itself a carriage return character. I ended up installing dos2unix and using that on my st.cmd file.
The other part of it was that I AM tracking my IOC in git, so I was getting pretty caught up in how to manage the issue globally. I'm still unsure how this can slip by unnoticed by git, and how I should tweak the way I use it to manage these mistakes in the future but that's not an EPICS question. The point is that dos2unix worked, and my st.cmd is running the ioc executable just fine now.
Thank you!
-----Original Message-----
Sent: Monday, October 03, 2016 6:45 PM
To: Crisp, Daniel <[email protected]>; [email protected]
Hi Dan,
../../bin/linux-x86_64/<PROD_IOC>^M: bad interpreter: No such file or
directory
Andrew is right. This is probably caused by Windows line endings in your st.cmd file. "dos2unix st.cmd" should fix your issue. In case you don't have that command try
sed -i -e "s/\^M//" st.cmd
Cheers,
Martin
P.S.: Are you tracking your IOC code in Git? If so Git should take care of converting line endings for you.
Martin Konrad
Control System Engineer
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824-1321, USA
Tel. 517-908-7253
Email: [email protected]
ioc executable being made corrupted Crisp, Daniel
Re: ioc executable being made corrupted Konrad, Martin
RE: ioc executable being made corrupted Crisp, Daniel
Prev: Re: EPICS build system DESTDIR support Andrew Johnson
Next: epics4 soft ioc Mezger Anton Christian (PSI)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: ioc executable being made corrupted Crisp, Daniel
Next: EPICS build system DESTDIR support J. Lewis Muir
ANJ, 06 Oct 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
